SolaraGuy.com • View topic - Another Newbie Question
Postby piratemike » Sun Jan 09, 2005 7:04 pm
Hello Everyone,
Well, I have another newbie question. I would like to install lowering springs, probably Eibach, on my 2001 Solara. The car has about 40K miles on it. Will the stock OEM struts work ok with lowering spring? By "work ok" I mean are there any interference problems or struts bottoming out...things like that, when using the OEM struts? Eventually I would also like to upgrade the struts but, if the OEM's will work for now, I will probably just leave them.
Later,
Mike
piratemike
Postby bassthrive » Sun Jan 09, 2005 7:47 pm
They will work OK, but they will wear much faster, meaning you will have to replace them eventually, spending double on labor. Do it the right way from the beginning and you will actually save money in the long run, not to mention, enjoy a nicely upgraded suspension the way it was meant to perform.
Off topic, but new members, please make the subject line related to what your post is about.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
