SolaraGuy.com • View topic - Supra fuel pump, and.........
Postby SleeperSolara » Sun Jan 09, 2005 10:04 pm
Ok, i was thinkin' about upgradin' my fuel system.
Can i use a Supra turbo fuel pump on my NA car??
What fuel pressure regulator should i use??
Or if i decide to go wit just a furl pressure regulator, what kind should i go wit??
Also what kind of fuel pressure gauge should i get??
Postby 1jzgte » Mon Jan 10, 2005 1:39 am
i hope you have something else in the works because a fuel upgrade alone will not yield more power... even with mild forced induction the solara fuel system should be sufficient..
1jzgte
Postby SleeperSolara » Mon Jan 10, 2005 3:24 am
I was just wonderin' if the fuel upgrade will work or not.
I was thinkin' about it, and more fuel would be better, i though.
Postby JoeB » Mon Jan 10, 2005 6:18 am
What 1jzgte said. The stock fuel system can deliver plenty of fuel to maintain a good A/F mixture. You won't gain power by adding more fuel. The reason to add more fuel is when you are increasing the air (supercharger) and you need more fuel to keep up the mixture. Simply adding a higher capacity fuel system without the rest will only cause problems. With no extra air coming in, you'd need some type of piggyback (Apexi/Split Second) to decrease the amount of fuel to maintain the proper mixture. Doesn't make sense. -JoeB
JoeB
Users browsing this forum: No registered users and 97 guests
