SolaraGuy.com • View topic - How do I disable my DRL's?
Postby tomcat » Thu Oct 31, 2002 8:03 pm
I have a 2000 SLE V-6 and I hate having daytime running lights. They even got me busted with my girlfriends husband. So I would really like to know if there is a way to disable them without causing any unwanted problems.
tomcat
Postby krook » Thu Oct 31, 2002 8:27 pm
refer to this:
http://www.pbase.com/image/223871
(heh, courtesy of Blaze)
see in the upper left corner of the engine bay? those two plugs, yellow and gray? unplug the yellow plug. viola!
krook
Re: How do I disable my DRL's?
Postby Blaze » Thu Oct 31, 2002 8:33 pm
tomcat wrote:I have a 2000 SLE V-6 and I hate having daytime running lights. They even got me busted with my girlfriends husband. So I would really like to know if there is a way to disable them without causing any unwanted problems.
girlfriends husband?! :o btw i think the plug is gray, the yellow thing is a sticker?
Blaze
Postby krook » Thu Oct 31, 2002 8:41 pm
yeah, well yea. . .that's what i meant. the uh. . .
the yellow plug with the gray sticker. just unplug the sticker by the yellow plug. :P
btw, i hope you're a female, tomcat. . .
cuz your "girlfriend's husband" don't sound too good.
krook
Postby tomcat » Fri Nov 01, 2002 7:05 am
Thank you all for your help. Just so you know, I am not a female. I am most certainly a guy :drinking:
tomcat
Postby *Charinee* » Fri Nov 01, 2002 7:12 am
There's another way to remove the automatic lights when it gets dark outside. This is fairly easy :angel: Quoted from Steve Schung, "You can simply disconnect the sensor on the dash (passenger side, just behind the windshield) to remove the automatic lights (at night). You have to pop the sensor out with a flat head screwdriver, and disconnect it. You can keep it all together with a ziptie if you would like to reconnect it in the future." :wink:
*Charinee*
Postby Missay » Fri Nov 01, 2002 11:44 am
tomcat wrote:Thank you all for your help. Just so you know, I am not a female. I am most certainly a guy :drinking:
either i hope you're referring to your female friend's husband or this just proves that we're all corrupted at solaraguy!! heheh
Melissa
Missay
SolaraGuy Ambassador
Disable DRL
Postby Iflyhd » Fri Nov 01, 2002 7:58 pm
http://www.tacomaterritory.com/~faqsect ... abldrl.htm
Toyota TSB on proper means to disable
Iflyhd
driving lights
Postby swimshady » Sun Dec 01, 2002 6:16 pm
i got bored enough once and read the owner manual and it tells u how to disable lights and even take them out to replace the bulb and whatnot ... if that helps any :wink:
swimshady
Postby all_red » Wed Oct 08, 2003 12:07 pm
I have a 2001 solara and couldn't find those yellow and grey plugs in the left upper corner of hood. is it different for my car model?
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby ChrYstiE » Wed Oct 08, 2003 12:38 pm
I don't know about you, but I can't get over the girlfriend's husband thing!
-Chrystie
08 VW GLI
ChrYstiE
Postby krook » Mon Jan 19, 2004 5:39 pm
*thread revival*!!!!
okay, i did the whole "unplug the grey connector" thing and it worked just fine the way it turned out; NO DRL but the twilight sensor was still active.
NOW, my DRL's are comin' back on, but the plug is still disconnected? WTF? what's really goin' on hurrr?
krook
Postby FLASH » Mon Jan 19, 2004 6:29 pm
Are you 100% POSITIVE that its the DRLs? A good one to make sure is to see that the headlamps are the ONLY exterior lighting that is on, not your corners or your rears. If everything is on, it is not the DRL. My frist thought was that maybe your twilight sensor is being covered, causing the car to think it is always dark out. I'm sure you checked that, if that's not it, maybe your sensor is blown or became defective somehow?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby krook » Mon Jan 19, 2004 7:14 pm
FLASH wrote:Are you 100% POSITIVE that its the DRLs? A good one to make sure is to see that the headlamps are the ONLY exterior lighting that is on, not your corners or your rears. If everything is on, it is not the DRL. My frist thought was that maybe your twilight sensor is being covered, causing the car to think it is always dark out. I'm sure you checked that, if that's not it, maybe your sensor is blown or became defective somehow?
nah. it's definitely my DRL's. i noticed it one afternoon when i stepped in front of my car. my parking lights were not on either. another surefire way i could tell my DRL's were working again is that my headlights automatically turn on RIGHT after i release my hand brake at night.
krook
Postby boneezy » Tue Jan 20, 2004 8:56 am
thats the only EASY way to disable the DRL AND Twilight sensor is to keep your e-brake up one notch.. Its not going to hurt your parking brake system because its only one notch up... all tha last notch is for is to trip the sensor turning on your headlights outside of your control.........
Also, theres a thread where you can go inside and actually disconnect the twilight/DRL system all together.... It was a Toyota service bulletin for people entering/exiting a military installation or just plain didnt like the DRL function
1999 SE-V6 5spd
160,xxx miles
boneezy
