SolaraGuy.com • View topic - tien and camber
tien and camber
tien and camber
Postby trdkamuri51o » Wed Jan 26, 2005 7:56 pm
can anyone with tiens tell me how the ride is and how your camber is?? did you need to get a camber kit to solve tire wear etc.,
tyhanks
trdkamuri51o
Postby Jackass-Jeff » Wed Jan 26, 2005 9:12 pm
How wide are your rims? x_X
No kit was needed... 18x8 +50
1GR-FE ftw!
Jackass-Jeff
Postby Vi3tT3kNiqz » Thu Jan 27, 2005 9:55 am
he means springs.
Vi3tT3kNiqz
Postby indiglosolara » Thu Jan 27, 2005 10:32 am
No chamber problem with tein and tokicos.
Just needed a aligment..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby lazyboyz69 » Thu Jan 27, 2005 11:13 am
i have camber bolts.... didn't know i didn't need them.. its only 30 bucks for camber bolts... with the tien/tokico...
lazyboyz69
Postby camcar se » Thu Jan 27, 2005 12:14 pm
Tein and Tokicos as well, no camber and wear is fine. Trial on error is the best way, go without, if you see uneven wear, get the kit, but untill that day, I would go without, cause chances are like myself and most others you wont need it. And go teins no other as far as springs go. My buddy has eibach with tok. and not only does my solara have a better drop in the front the cornering and stability is great, and the ride is in my opinion better then stock unless you hit a pretty big jolt, but you wont be dissapointed the ride quality is still very suprising,our platfrom is really just too heavy to have a bad ride, it would take a hell of a spring to make the ride real "bad". Hope that helps.
camcar se
