SolaraGuy.com • View topic - no turnsignals
no turnsignals
no turnsignals
Postby jazzlara » Sun Jan 30, 2005 11:06 am
ok, i installed my system months ago. the REM cable is spliced into the cig lighter. everything was copasetic for a long while. today the signals all of a sudden went out along with the hazards.
if i hit the console sometimes they will come back on. not sure what it is. i still need to check the fuse, by the way, is there a single fuse for the turnsignals?
any other suggestions
jazzlara
Postby Yanks0114 » Sun Jan 30, 2005 12:49 pm
well it wouldn't be a fuse issue because if you hit the console they come back
Behind the hazard button there is a connector. If that connector is disconnected you won't get turn signal or hazards. Maybe when you reconnected your center console, you didn't snap that in all the way
Postby jazzlara » Sun Jan 30, 2005 1:26 pm
Yanks0114 wrote:well it wouldn't be a fuse issue because if you hit the console they come back
fixed...sure enough it was the flasher connector. must have been a mouse in the dash or somethin f'ing with me. lol
thanks yanks, easy answer....easy fix.
jazzlara
