SolaraGuy.com • View topic - Celica steering wheel help
Postby SpikedMantis » Tue Feb 15, 2005 8:56 am
I installed the steering wheel, but I need some help with wiring the horn and cruise control. Has anyone else done this successfully? I know some members have put the wheel on, but I haven't heard anything about the horn or cruise control. Thanks!
SpikedMantis
Postby Mole » Tue Feb 15, 2005 9:04 am
it was not plug and play?
the only person that i know that did the swap was happy aggies.
pm him.
Postby SpikedMantis » Tue Feb 15, 2005 9:25 am
The airbag was plug and play, but the other parts are not. They don't match up exactly.
SpikedMantis
Postby sunrise_solara » Tue Feb 15, 2005 12:03 pm
Post some pics
sunrise_solara
Postby SpikedMantis » Tue Feb 15, 2005 2:48 pm
sunrise_solara wrote:Post some pics
Of the wheel or the wiring? If the wiring, it will take a bit because I'll have to take it apart again.
SpikedMantis
Postby DatSRBoi » Tue Feb 15, 2005 5:11 pm
Take Pics of both. So I can l"try" ook up on my repair manuel haha
Postby impactX » Wed Feb 16, 2005 8:41 am
I am not sure about the the Celica wheel, when I installed my Momo, I had to spice a wire with gives 12V.
Use a voltmeter to find out which one. You will have to spice two since you will need to connect the ground also.
impactX
Postby SpikedMantis » Wed Feb 16, 2005 10:39 pm
Here's a pic of it. I'll try to get more when I have time to remove everything to see the wiring.
http://www.imagestation.com/album/pictures.html?id=2130608840&idx=1
SpikedMantis
Postby SpikedMantis » Thu Oct 20, 2005 3:24 pm
Okay, I've finally found some time to do this. I'm going to hot wire my horn and cruise control this weekend, but if anyone has any wiring diagrams for a 2001 Solara and a last gen Celica, it would be most helpful.
SpikedMantis
Postby Solorange » Thu Oct 20, 2005 7:48 pm
Im sorry I cant help you with your problem, but I was wondering how much a celica steering wheel cost and if it comes in ivory? I was just wondering cause i may replace my steering wheel in the future. The leather on it is getting worn out pretty bad.
Postby krook » Thu Oct 20, 2005 7:51 pm
Solorange wrote:Im sorry I cant help you with your problem, but I was wondering how much a celica steering wheel cost and if it comes in ivory? I was just wondering cause i may replace my steering wheel in the future. The leather on it is getting worn out pretty bad.
call your local toyota parts store. i think mines said it would be about 100 somethin' dollars...
krook
Postby SpikedMantis » Fri Oct 21, 2005 12:32 pm
I'm pretty sure the celica wheel didn't come in ivory. I bought my wheel on ebay with an airbag for about 250, but it was used.
SpikedMantis
Postby Solorange » Fri Oct 21, 2005 1:57 pm
Yeah I had a feeling ivory didnt come in celicas. Come to think of it that would look just downright ugly in that car.
Krook that is cheap if you found one for 100 something bucks. I was thinking the minimum would be like $450
Postby krook » Tue Oct 25, 2005 12:10 pm
hrrmmmm...you're right. now that spikedmantis mentioned it, i think it was more than 100. :|
damn. that wheel is pricey.
krook
Postby jeffrey_o » Tue Oct 25, 2005 2:53 pm
Hrm... on the MR2 the steering wheel actually is more or less plug and play for the horn and CC, however... the airbag doesn't work at all and it won't be working due to different sensor readings. I would assume that all you'll have to do is splice the wires directly to each other instead of using their harness plugs.
1993 MR2 Turbo - 348rwhp @ 16psi.
She's a track beast, but will still own you in the straights.
jeffrey_o
