SolaraGuy.com • View topic - suspension set..
suspension set..
suspension set..
Postby SolaraTypeR » Thu Feb 24, 2005 2:04 pm
i kno i kno.. this topic is discussed over and over and over again.. but i just wanna kno how this one sounds..
teins on KYB??
SolaraTypeR
Postby thealkimo » Thu Feb 24, 2005 4:08 pm
that's fine...
most people tho have tein/tokico
thealkimo
Postby SolaraTypeR » Thu Feb 24, 2005 10:11 pm
would there be any riding problem? softer/stiffer? follow up problems? too low??
SolaraTypeR
Postby TadS » Fri Feb 25, 2005 6:02 am
No, problems, but if you're paying labor I would go ahead and spring for Tokicos, as they should last longer.
TadS
Postby RichD978 » Fri Feb 25, 2005 6:05 am
TadS u have a sweet ride man but can you help me out? Your indiglo guages... whats this i hear about wiring. Cant you just take the old ones off and replace them with the aftermarket ones? Im not so good at wiring and wondering if i can avoid it. If i cant avoid the wiring. How hard or easy is it on a rate of 1 to 10? Thanks
RichD978
Postby TadS » Fri Feb 25, 2005 6:15 am
RichD978 wrote:TadS u have a sweet ride man but can you help me out? Your indiglo guages... whats this i hear about wiring. Cant you just take the old ones off and replace them with the aftermarket ones? Im not so good at wiring and wondering if i can avoid it. If i cant avoid the wiring. How hard or easy is it on a rate of 1 to 10? Thanks
Thanks for the complement, you should start a new thread for new questions :wink:. You have to wire up power to the indiglo gauges. There are alot of places in the dash you can tap for power. The HVAC controls lighting circuit is the one I used. This way I can only turn on the indiglo when the circuit is live, and they shut off when I turn my lights off. I would say it is pretty simple, if you have any buddies with any skills talk see if they can help you. There are alot of Solara Guy's from Mass., if you poke around the forum maybe one of them is close to where you're at.
TadS
Postby RichD978 » Fri Feb 25, 2005 6:22 am
thanks, i wasnt' sure which forum to post in. I did in one but no one responded, thought since you were in this forum i could grab your attention. It worked though haha . Sorry
RichD978
Postby SolaraTypeR » Fri Feb 25, 2005 10:13 am
aite.. thanx.. cuz i'm running low on cash and i was gonna get kyb instead..
SolaraTypeR
Postby adam2562 » Tue Mar 01, 2005 1:47 pm
JIC i'll sell u mine for $800
Adam - 99 V6 5spd 165k -SOLD
adam2562
