SolaraGuy.com • View topic - Jim's fuel kit
Jim's fuel kit
Jim's fuel kit
Postby lilm » Wed Mar 16, 2005 11:28 am
what exactly is it...?
Post in the correct forum next time!
lilm
Postby Astro » Wed Mar 16, 2005 11:55 am
It's a bigger filter and hoses, along with a better T-fitting. This T-fitting is opened much more than the stock one.
Postby s15lara » Wed Mar 16, 2005 12:11 pm
how much is the fuel kit?
s15lara
Postby Duffman » Wed Mar 16, 2005 8:26 pm
Is it a DIY job? And where do we order?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby impactX » Wed Mar 16, 2005 8:59 pm
200 bucks for a couple of T-hoses?
Can't you get those at home depot?
impactX
Postby TRD_solaRa » Wed Mar 16, 2005 10:46 pm
Well Jim already did the R&D so that these would custom fit the fuel rails for the 1MZFE
TRD_solaRa
Postby eyedea » Wed Mar 16, 2005 10:50 pm
Image[/
5SP 02 SE V6 SC 1MZFE .......RIP ...
2003 Infiniti M45 =340hp of RWD sex
eyedea
Postby DatSRBoi » Wed Mar 16, 2005 11:13 pm
Think we can do group buy and get it down to 150 shipped? I htink 200 is kind of out of the universe for some tubes and metal and a filter... I know its well worked out and all but still think about it you know. Thast allot of money. And it IS a tube,metal, and filter..
So group buy anyone? Can anyone get this started? 150 and below Im in. I do kind of need it.
Plus is it worth it since my car is only cat back and K&N drop in? When I pedal my car hard I can feel it lacking something...
Postby lazyboyz69 » Wed Mar 16, 2005 11:26 pm
i just got a new fuel filter and a fuel pump and pour octane booster..... i'm s/c octane booster makes the biggest difference... maybe you just need to pour fuel injector cleaner in your car.... 200 bucks.. 150 alone is too much for hoses... i rather spend 150 on octane booster.....
lazyboyz69
Postby captainpimp » Wed Mar 16, 2005 11:33 pm
im in. i do agree, 200 is a little steep.
captainpimp
Postby ChargedSolara » Thu Mar 17, 2005 12:03 am
DatSRBoi wrote:Think we can do group buy and get it down to 150 shipped? I htink 200 is kind of out of the universe for some tubes and metal and a filter... I know its well worked out and all but still think about it you know. Thast allot of money. And it IS a tube,metal, and filter..
its worth it for s/c'ed cars i believe.. i don't know if it offers benefits for n/a guys..it definitely helps prevent knock sensors from blowing from what i hear, and it keeps the car from running too lean under higher boost.
2008 C6 LS3
ChargedSolara
Postby Astro » Thu Mar 17, 2005 1:05 am
lazyboyz69 wrote:i just got a new fuel filter and a fuel pump and pour octane booster..... i'm s/c octane booster makes the biggest difference... maybe you just need to pour fuel injector cleaner in your car.... 200 bucks.. 150 alone is too much for hoses... i rather spend 150 on octane booster.....
You don't have to buy Jim's kit, you can just get your own parts. The greatest benefit from this mod is the bigger t-fitting. This will allow even flow between both fuel rails, plus even more fuel. Compare the stock t-fitting with the one in Jim's kit. Tell me what you think? More fuel, more power? Well, just think what it'll do with the octane booster, because I get a very nice jump at around 4500 rpm. 8)
Postby Whatever » Thu Mar 17, 2005 1:54 am
hmm... I kinda wanna do that. Does taht lower your MPG? and is it bad for engine?
Whatever
