SolaraGuy.com • View topic - Foreign Affairs 1MZ-FE Torque Rod group buy
Postby trd4life » Fri Mar 18, 2005 4:05 pm
Price pending, we need 10 orders . Throw your name in on the thread if your want in. So far we have.
As posted by Jim a couple months ago.....
1)trd4life
2) JoeB
3)Doug Lila
4)Greg
5)wiz2
6)shidosha01
7)ruffrydasean
8 ) Castro
9)Gman
"I have been doing a little R&D on a simple yet effective torque rod for the SuperSolara. I was wondering if anyone else has been working on this. I know there has been some work done on firmer motor mounts by Eric; though these are very effective at controling engine movement, they also tend to be noisy and harsh.
You may have noticed a small shock absorber mounted between the transmission and lower crossmember just to the driver's side of the header. The function of this is to help control engine twisting during harsh accelleration. I have replaced this shock unit with a Heim joint and steel threaded rod on my car. I was concerned about the possibility of noise and vibration, however, there is none of that. The motor mounts still make for a quiet ride, but engine twist has been eliminated and transient response is improved. It is easier now to break the tires loose during quick starts. It is a do it yourself improvement worth the low cost. This would especially benefit manual transmission applications.
All you need is a 10mm male Heim joint and a 9" piece of 10mm threaded rod, and a few 10mm nuts. You can use poly shock bushings for a firmer feel. Installation shouldn't take more than 1/2 hour."
_________________
Postby lazyboyz69 » Fri Mar 18, 2005 4:26 pm
how much would this cost?
how the heck did you get your car to run 13.5?
lazyboyz69
groupbuy
Postby trd4life » Fri Mar 18, 2005 4:31 pm
The cost is pending but be prepared to spend between $35-$70.
My car ran a 13.5 with a s/c, 3"y pipe, CAI, ignition, clutch/flywheel, and upgraded fuel system.
Re: Foreign Affairs 1MZ-FE Torque Rod group buy
Postby wiz2 » Fri Mar 18, 2005 4:50 pm
1)trd4life
2) JoeB
3) wiz2(i'd like some pics :) )
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Group Buy
Postby trd4life » Fri Mar 18, 2005 5:13 pm
1)trd4life
2) JoeB
3) wiz2
4) Greg
Postby JoeB » Fri Mar 18, 2005 5:31 pm
Although Jim mentions this is especially good for manuals, I am especially interested in this because if you have an automatic, the front motor mount cannot simply be replaced by a urethane mount like with the manual. With the automatic, it is a grease filled monster mount. Stabelizing the transmission should just about take care of any movement in the front all together. I am SO in for this 1! Thanks Gabe for digging this back up. I forgot about it. I was waiting for it to become a group buy or Jim to offer a kit and I forgot about it.
The other thing I'd like (if you're reading this Jim :wink: ) is urethane bushings for the dogbone. -JoeB
JoeB
Postby shidosha01 » Fri Mar 18, 2005 6:29 pm
I'm in. I'll give it a try. Thanks for the PM Gabe, Greg, and Joe! 8)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Group buy
Postby trd4life » Fri Mar 18, 2005 6:31 pm
1)trd4life
2) JoeB
3) wiz2
4) Greg
5)shidosha01
Postby captainpimp » Fri Mar 18, 2005 8:52 pm
anybody got a pic of it?
captainpimp
Re: Group buy
Postby CASTRO » Fri Mar 18, 2005 8:54 pm
trd4life wrote:1)trd4life
2) JoeB
3) wiz2
4) Greg
5)shidosha01
im in! wait.. so once again, it can work with an auto right? and would I have any problems later on; Im planning to swap in a manual sometime
CASTRO
Postby thakidd » Sat Mar 19, 2005 10:15 am
1)trd4life
2) JoeB
3) wiz2
4) Greg
5)shidosha01
6)thakidd
hopefully its only 35-70 cause im on a budget
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby DatSRBoi » Sat Mar 19, 2005 11:17 am
how much first before I say im in.Pics too?
Postby Paladin06Greg » Sat Mar 19, 2005 11:27 am
Come on Texas, think big and jump onboard.. 8)
DatSRBoi wrote:how much first before I say im in.Pics too?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Sat Mar 19, 2005 11:50 am
Guys, shouldn't this post be in the aftermarket section??
Paladin06Greg
Torqued Solara
Torqued Solara
Postby shidosha01 » Sat Mar 19, 2005 12:02 pm
Paladin06Greg wrote:Guys, shouldn't this post be in the aftermarket section??
You're right.
shidosha01
