SolaraGuy.com • View topic - Problem with whiteline sway bars
Postby gnaw_divad » Fri Mar 25, 2005 6:24 pm
Alright guys... i have a problem..
I purchased and installed the whiteline front and rear sway bars close to a year ago. Recently i've been hearing loud CLUCKING noises in the front left tire espeiclally when i turn left, so i went in for a diagnostics.
They just called me today and told me that the brackets on BOTH sides (left and right) are broken. And they have no idea how to fix it cause they say if i get a new bracket it might break just the same.
Has anybody had this problem with the whiteline sway bars?? I had them professionally installed at TECH 3 motors in San Jose, do you guys think it could have been an install problem or a manufacturing problem. Or if whiteline will send me new brackets ??
ANY RESOLUTION WOULD BE GREATLY APPRICIATED, THANK YOU
-David
gnaw_divad
Postby SC V6 » Fri Mar 25, 2005 6:29 pm
quit driving like a mad man?
SC V6
Postby 1jzgte » Fri Mar 25, 2005 6:39 pm
you have chickens under your hood
1jzgte
Brackets
Postby PDX SuperSolara » Fri Mar 25, 2005 6:59 pm
I would just replace the brackets. I have seen this happen before, replacement brackets usually don't break.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Paladin06Greg » Fri Mar 25, 2005 7:42 pm
When I first got my Whiteline FSB I used th OEM brackets. I really didn't like the way they felt, or looked so I contacted WL for replacement a solution. Then sold me the oversized heavy duty straps. The ride and handling is much better. Give it a shot..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby gnaw_divad » Fri Mar 25, 2005 8:27 pm
Paladin06Greg wrote:When I first got my Whiteline FSB I used th OEM brackets. I really didn't like the way they felt, or looked so I contacted WL for replacement a solution. Then sold me the oversized heavy duty straps. The ride and handling is much better. Give it a shot..
THANKS PALADIN06.. that sounds like the best plan way !! do you remember the number you used to contact whiteline???
thanks
-david
gnaw_divad
Postby gnaw_divad » Fri Mar 25, 2005 8:29 pm
oh sorry, and i forgot to ask how much did you pay for them...
THANKS
gnaw_divad
Postby CASTRO » Fri Mar 25, 2005 8:35 pm
gnaw_divad wrote:oh sorry, and i forgot to ask how much did you pay for them...
THANKS
im in the same boat... I usually beat up my car at the track as well as some auto-x events and almost every time the nuts/bar brackets always get loose. Paladin, whats the difference between the OEM and whiteline versions?
CASTRO
Postby Paladin06Greg » Fri Mar 25, 2005 10:52 pm
Well you're in luck because when I got mine I had to get it shipped in from AUS but now try these:
http://www.pdm-racing.com/products/toyota_corner.html
http://www.whiteline.com.au/
http://www.ctmotorsport.com/store/scrip ... ategory=31
Good luck!
Paladin06Greg
Torqued Solara
Torqued Solara
Postby wiz2 » Sat Mar 26, 2005 7:55 am
I had the same thing happen to me about a month after I put my front bar on. I replaced both bracktes with new factory brakests. I havent had a problem in almost 3 years.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby gnaw_divad » Tue Mar 29, 2005 11:31 pm
I contacted Whiteline and this was their reply...
Thank you for supporting Whiteline sway bars.
The sway bar to suit your vehicle is sold with only the 'D'-bushes (sway
bar to chassis mounting bushes), as we do not have a record of sway bar
end links that would be required to suit your vehicle.
We believe that the Original equipment links would be easier to come by
and cheaper for you to purchase in the US.
If you have trouble locating some links to suit your vehicle, feel free
to contact me again, but I will require a complete set of dimensions of
your existing links and we will try and match something up for you.
Paladin06Greg- Did you say you got a set from whiteline?? If so, did you have to special order them..
Also, are the "brackets" the same as the bushings for those people who have said they have broken brackets?? The autoshop told me that i needed to replace both the brackets and the bushings??? but from what the guy wrote me it sounds like there is no brackets, ONLY BUSHINGS???
WIZ2 - did you replace the brackets or the bushings??
THANKS A LOT,
-David
THANKX
gnaw_divad
Postby Paladin06Greg » Wed Mar 30, 2005 4:14 am
Initially I used the OEM bracket and bushings but after awhile I decided I did not like the way they fit. They did not mount flush at the mounting point. IMO
I contacted WL via e-mail and got almost the same response you got. That's when I called them and got what I needed. I got two sets of bushings. One was the same outside diameter as the OEM bushings, and I also got a heavy duty bracket and bushing set and those are the ones on my car. I'll see if I can locate the paperwork and get back with you.
gnaw_divad wrote:I contacted Whiteline and this was their reply...
THANKS A LOT,
-David
THANKX
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Wed Mar 30, 2005 5:36 am
I'm sorry I can not find the receipt for the replacement straps and bushings. Perhaps if you ask them to check their records for the sale to Gregory Anderson at 6 Cross Creek Ln, Seymour CT. in 2003/04 they can use the numbers from my file.
I don't live in CT anymore.
Good luck.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Wed Mar 30, 2005 2:37 pm
hmmm keep me posted on this issue cause im most likly going to have some problems in the near future also
SC V6
Postby 1st Gen Sol » Wed Mar 30, 2005 8:09 pm
That goes for me also becuase I need new sway bar links since the front sway is so daym think compared to the stock one.....
Keep us informed on this and let us know wussup.
Just an idea but if they can find Paladin06Greg's paperwork maybe we can go in together on the parts that we need and perhaps save some cash...... :roll:
1st Gen Sol
Stock Sleeper
Stock Sleeper
