SolaraGuy.com • View topic - steering wheel hub..
Postby SolaraTypeR » Mon Mar 28, 2005 7:50 pm
i just brought the momo jet steering wheel.. but i can't seem to be able to find the hub on eBay~ :o HEELP~~
SolaraTypeR
Postby SolaraTypeR » Thu Mar 31, 2005 1:26 pm
which year's celica? btw.. i got the gen 1 solara.. so i can find the current celica's hub and fit it rite?
SolaraTypeR
Postby impactX » Fri Apr 01, 2005 2:20 pm
Yes, 7th Gen Celica hub.
And you will really have to be creative to get your horn back.
The back of the hub has a gold-colored plating, which is to be used for + terminal of the horn button. After disconnected the airbag and everything, you will have 4 lines on the plug. Find the one that has a constant flow of 12V even when the car is off, then you have a horn line. Then you will have to tap into this line with a 20gauge wire, and fabricate something so that when everytime you turn the wheel, this wire will be rubbing the back gold-colored plating. This is the only way I found that works. I went on multiple Celica forums and almost none of them had a clue on how to make the horn work.
impactX
