SolaraGuy.com • View topic - What else to get???
What else to get???
What else to get???
Postby that1mexguy » Sun Apr 03, 2005 8:36 am
Ok I'm really looking into getting a Supercharger within a few months, but I don't want to just get it and then have my engine blow up, my brakes go out on me, etc. so I'm trying to compile a list of "MUST UPGRADE" items so that I can do it all at once... for example, when I get it I want to already have:
1. Jim's fuel line upgrade
2. SAFC II
3. Bakes upgrade (rotors, pads and brake lines)
4. Jim's torque rod upgrade
5. ........
what else? what do you guys recommend as a MUST HAVE. I am not looking at "NICE TO HAVEs", but only items that are critical to keep my car running nice and smooth, or do you think that should do it?
that1mexguy
Postby djsaltine » Sun Apr 03, 2005 9:12 am
Don't be a baby...throw that ish in!! :P
http://fairtax.org
djsaltine
Postby thakidd » Sun Apr 03, 2005 9:36 am
i dont think you wiill need the safc,and brakes...i would get
denso ik22 plugs
new sparkplug wires
jims fuel mod and u should be all set
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Re: What else to get???
Postby TRD_solaRa » Sun Apr 03, 2005 11:19 am
that1mexguy wrote:Ok I'm really looking into getting a Supercharger within a few months, but I don't want to just get it and then have my engine blow up, my brakes go out on me, etc. so I'm trying to compile a list of "MUST UPGRADE" items so that I can do it all at once... for example, when I get it I want to already have:
2. SAFC II
5. ........
The first 2 are ARE the MOST important . . . but I think that you most defnitely NEED Jim's Fuel Line Upgrade just to be safe . . . $200 now is well worth it rather than risking $600 on fixing shet. SAFC-II can only help you in tuning the air/fuel ratio better, so of course it would be useful as well but not as necessary as Jim's.
TRD_solaRa
Postby StockSolara » Sun Apr 03, 2005 11:22 am
^^^ plus:
port and polish head
5 angle valve job
forged internals
tranny work
200 shot of NOS
13 PSI pulley
haha nah I'm just playing but yeah what you're going to get and plus what TRD_solaRa said is good.
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby s15lara » Sun Apr 03, 2005 11:45 am
what about the walbro fuel pump? wouldnt that help? and be a neccesity?
s15lara
Postby arch.HI » Sun Apr 03, 2005 1:06 pm
The only things you NEED are spark plugs and spark plug wires because it will be a pain to change them later. I would also get Jim's fuel upgrade to be safe. Everything else is good to go.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby thakidd » Sun Apr 03, 2005 3:25 pm
Agreed.
14.3@96 60ft 2.173
thakidd
Postby wiz2 » Sun Apr 03, 2005 7:34 pm
1. IK 22 plugs
2. Change pcv valve(while its all apart)
3. Boost guage to make sure boost is engaging.Just becuase you here it,dont mean you got it !
Depending on miles
1. go ahead and change alll belts, even the timimg belt prior to boost.
2. upgrade all vac lines. when the old ones crack or blow off you'll think its the SC f'n up!
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Astro » Mon Apr 04, 2005 10:27 am
All you really have to do is Jim's fuel upgrade. That's all I've done for over a year now and no prob's. SAFC in not really that important IMO, unless you want to change pulleys. If you have some mileage on your ride, you should change the spark plugs and wires now. If you don't, you'll have to pay to have the s/c removed and intalled again later.
Postby 99SEAUTO » Mon Apr 04, 2005 9:58 pm
Jim's torque rod upgrade ------ WHAT IS THAT
99 SE V6
99SEAUTO
Postby ChargedSolara » Mon Apr 04, 2005 11:42 pm
99SEAUTO wrote:Jim's torque rod upgrade ------ WHAT IS THAT
http://www.zer0.info/solaraguy/viewtopi ... sc&start=0
2008 C6 LS3
ChargedSolara
