SolaraGuy.com • View topic - Ground Control Shocks for SOlara
Postby SmokeoUtRObert » Mon Apr 04, 2005 2:16 pm
Does anyone have these shocks?? i was wonderin how much the drop is
SmokeoUtRObert
Postby bassthrive » Mon Apr 04, 2005 2:22 pm
struts dont drop you, springs do
i think the most popular combo on the boards is tein springs, tokico struts. a lot have eibach too. wherever you buy them from will indicate the drop in front and back. i like my teins, slightly raked drop to the front makes up for the fact that our front wheel well gap is more dramatic than the rear.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Re: Ground Control Shocks for SOlara
Postby TRD_solaRa » Mon Apr 04, 2005 7:46 pm
SmokeoUtRObert wrote:Does anyone have these shocks?? i was wonderin how much the drop is
Ground Control does NOT make struts . . . they make adjustable coilovers for our car. The drop was somewhere around 2.5" or so in the front and 2.75" - 3" or so in the rear. BUT they don't fit correctly with the TRD struts (due to the way the coilovers sit on the "cup" of the strut) . . . I would only recommend getting the Tokico struts if you were to get the Ground Control coilovers. I used to have them on my old Prelude SH, but the ride was quite bumpy. I've heard the same with those who have Solaras as well. Up to you tho, but it does slam the car to the ground! ( 8) meannnnn 8) ) But if you don't wanna sacrifice the ride quality and get a nice ADJUSTABLE drop . . . go with either the TEIN or JIC Magic full coilover suspension. Shootz
TRD_solaRa
Postby SmokeoUtRObert » Mon Apr 04, 2005 7:59 pm
What about using stock shocks with the ground control coilovers??? will the ride be bumpier than getting the high pressured shocks from tokico???
SmokeoUtRObert
Postby Astro » Mon Apr 04, 2005 8:02 pm
TRD_solaRa wrote:go with either the TEIN or JIC Magic full coilover suspension. Shootz
^That'd be the best way^ - if you got the dough.
If not, go for TEIN springs and Tokico shocks.
Postby ICrazyChrisI » Mon Apr 04, 2005 8:22 pm
Don't get Ground Controls. Looks nice when I had it slammed on the ground, felt unsafe while on the freeway..way too bouncy/unpredictable.
ICrazyChrisI
Postby Jackass-Jeff » Mon Apr 04, 2005 8:30 pm
buy the ground controls if you want to die
:D Have a nice day!
1GR-FE ftw!
Jackass-Jeff
Postby 1st Gen Sol » Mon Apr 04, 2005 8:36 pm
I got a set of Ground Controls also with the Eibach Springs.
Can I just use the springs with a set of Tokico's and leave the Ground Controls out ? ? ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby TRD_solaRa » Tue Apr 05, 2005 6:07 pm
1st Gen Sol wrote:I got a set of Ground Controls also with the Eibach Springs.
heh?
do you mean by "leaving the Ground Controls out" as in switching from Ground Control coilovers to Eibach springs? or what? if you use the Eibach springs, of course you can't use the Ground Control coilovers at the same time. Try rewordin a bit . . .
TRD_solaRa
Postby 1st Gen Sol » Wed Apr 06, 2005 7:53 am
I have the ground control coilovers with the eibach springs setup. I don't have the tokico shocks and struts yet.......but I've been hearing so much bad stuff about the ground controls that I wanted to know if I can use the Eibach springs that came with the ground controls by itself with a set of tokico shocks & struts.....leaving the ground controls off my car and just going with the Eibach springs and Tokico Shocks and struts.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Jackass-Jeff » Wed Apr 06, 2005 1:52 pm
heh?
ground control consists of:
eibach springs
"adjustable" spring seat... to lower/raise the car more
You need to provide your own strut.
1GR-FE ftw!
Jackass-Jeff
Postby 1st Gen Sol » Wed Apr 06, 2005 1:59 pm
So does that mean I can just use the Eibach springs and get my own shocks & struts ? ? ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby 562solara02 » Wed Apr 06, 2005 3:41 pm
hit up milt he has some ground controls for sell
Image<--- MY CAR ALARM
562solara02
Postby Vi3tT3kNiqz » Wed Apr 06, 2005 6:04 pm
^^ how much? i want to buy the fronts.
Vi3tT3kNiqz
Postby ICrazyChrisI » Wed Apr 06, 2005 7:40 pm
Vi3tT3kNiqz wrote:^^ how much? i want to buy the fronts.
Alright, I officially give up helping people on this forum.
ICrazyChrisI
