SolaraGuy.com • View topic - Kaaz LSD Gear Oil? Or can I.....
Postby shidosha01 » Wed Apr 13, 2005 8:29 am
Well I've just ordered a stronger clutch and lightened flywheel from SPEC. I"m also going to change the gear oil while everything is out. I've used the Kaaz gear oil and looks like conventional gear oil to me. Anyone here try to use Red Line or any other synthetic gear oil on their LSD? Ericsol?
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby SC V6 » Wed Apr 13, 2005 10:53 am
I used some of the Kaaz gear oil, but mostly 80w90 gear oil w\ a limited slip additive
SC V6
Postby TRD_solaRa » Wed Apr 13, 2005 12:30 pm
SC V6 wrote:I used some of the Kaaz gear oil, but mostly 80w90 gear oil w\ a limited slip additive
Same heRR man . . . I stuck wit KAAZ oil jus to be safe.
TRD_solaRa
Postby EricSol » Wed Apr 13, 2005 8:31 pm
I tried synthetic and had problems shifting when cold. Conventional with limited slip additive added worked best for me.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby shidosha01 » Wed Apr 13, 2005 8:57 pm
EricSol wrote:I tried synthetic and had problems shifting when cold. Conventional with limited slip additive added worked best for me.
Thanks for the feedback Eric. Glad to see you're still around.
shidosha01
Postby Alex(AUS) » Fri Apr 15, 2005 2:38 am
Geez 485rwhp :o ... thats pretty crazy stuff (particularly N/A).
Alex
Alex(AUS)
Postby Paladin06Greg » Fri Apr 15, 2005 2:41 am
That's why I just got the banks approval for an 05 GTO.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby EricSol » Fri Apr 15, 2005 7:12 am
Alex(AUS) wrote:Geez 485rwhp :o ... thats pretty crazy stuff (particularly N/A).
Alex
I am doing a intake manifold and throttle body right now to get over the 500 hump.
The headers are to small so after I correct I am really trying for 550rwhp NA.
1999 Solara 296 whp
EricSol
Postby Alex(AUS) » Fri Apr 15, 2005 7:58 am
We (Aussies) built the thing and I dont think we can get close to that (550rwhp) N/A :D You must have some pretty trick hardware. What have you done Eric :o ?
Alex
Alex(AUS)
Postby Alex(AUS) » Fri Apr 15, 2005 8:03 am
Just for your info. Here is our best (for the moment - GTS to come).
http://www.hsv.com.au/cars/vz/main/gto.html
Alex(AUS)
