SolaraGuy.com • View topic - Those With Yellow Tint on their FOg Lights...
Postby cruze105 » Thu Apr 14, 2005 11:03 am
How did you get it to stick, It seems to fall off after driving around with and I have AIr Bubbles in them and i used soap and water to get it out but no go. Anyone have DIY on this ?
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby cdeez » Thu Apr 14, 2005 11:37 am
use a heat gun or poke the holes where the bubbles are at and then keep pressing down..its hard to get it perfect with if you don't know how to work with tint. if you use that thicker stuff, I forgot what its called, that stuff is easier to work with. doesn't bubble up as much.
last standing...
Socalara...
cdeez
Postby boneezy » Thu Apr 14, 2005 11:43 am
---> lamin-x
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby Jackass-Jeff » Thu Apr 14, 2005 12:08 pm
cdeez wrote:use a heat gun or poke the holes where the bubbles are at and then keep pressing down..its hard to get it perfect with if you don't know how to work with tint. if you use that thicker stuff, I forgot what its called, that stuff is easier to work with. doesn't bubble up as much.
my buddy is gonna paint my fogs for me (same idea as blacking out the tail lights, but painting the lamp a different color...) i'll post pix when it comes out :D
maybe I should get amber instread?
1GR-FE ftw!
Jackass-Jeff
Postby 562solara02 » Sat Apr 16, 2005 9:40 pm
i tried to get most of the bubbles out kinda hard then i let them sit in the sun a lil then worked out the bubbles a lil more theres only small bubbles on mine u cant see them unless u really look close oh yeah thanks chan
Image<--- MY CAR ALARM
562solara02
Postby cruze105 » Sun Apr 17, 2005 6:51 am
me and jon gonna try today to do it, well see how it goes
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
