SolaraGuy.com • View topic - anonying sound with tokico/tein combo
Postby S99Solara » Thu May 12, 2005 9:28 pm
on my left rear wheel i have an anonying metal hiting metal sound whenever i run over a speed bump or pot hole., it is very sensitive!! i believe what cause this is the stabilizer bar link is loose, i have tighten it up earlier this and the sound was gone but now its back! anyone else expereince with this before? i need some help!!!!! :cry:
06 4Runner V8 SE
98 1MZ-FE Camry
SOLD! 1999 SE V6 5 Speed,Clutch Masters Stage 2 Clutch Fidanza Lightweight Flywheel, Tein / Tokico, Philips power2night GT150 H4, TWM Shortshifter, Optima Red Top Battery, TRD RSB
S99Solara
Postby Turbosolara » Thu May 12, 2005 10:33 pm
put some locktight glue on it
Postby lazyboyz69 » Fri May 13, 2005 12:32 am
did you put the rubber thing on top of the spring back on?
lazyboyz69
Postby S99Solara » Fri May 13, 2005 8:56 am
yes
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby S99Solara » Fri May 13, 2005 12:26 pm
--1LOKEDOUTSLE-- wrote:Sometimes when the springs do not sit correct on the strut seat, it may create a clunking noise, my advice is to take the strut/sping apart and retighten... You will never know by second guessing.....
it looks straight when i re-tight the stablizer-bar link bolt earlier this week.
it just happen that clunking noise come back like 2days later.
are you local dude? i need tools + hands =)
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby S99Solara » Fri May 13, 2005 2:08 pm
Whats local to you... I live in SOCAL... I'll help you if you are in this area....
yeah i'm in socali too, @ monterey park
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Users browsing this forum: No registered users and 68 guests
