SolaraGuy.com • View topic - Rear Sway bar
Rear Sway bar
Rear Sway bar
Postby SleeperSolara » Fri May 13, 2005 8:08 am
Ok i ok how thick the WhiteLine RSB's are.
But how thick is the TRD RSB??
Also where can i get a WhiteLine RSB besides the AU??
Also what's the part number don't know which one it is, already looked on cataloge for them.
Postby Jon11582 » Fri May 13, 2005 9:31 am
I forget the number, but the TRD has street and track settings. Whiteline only has one setting. The TRD street setting is a less stiff setting than the whiteline, but the track setting is more stiff.
I think its equal to 21mm for TRD - street, and 25mm for track, and the whiteline is 23mm, but I could be wrong.
EDIT - as corrected below by other member, Its:
19mm for TRD - Street
21mm for TRD - Track
20mm for Whiteline.
2000 Black Solara SE
Jon11582
Re: Rear Sway bar
Postby StockSolara » Fri May 13, 2005 10:25 am
SleeperSolara wrote:Ok i ok how thick the WhiteLine RSB's are.
The part # is on there catalog just look closely. You may purchase it from www.ctmotorsport.com
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby 1st Gen Sol » Fri May 13, 2005 10:44 am
Here's a TRD rear sway bar for sale on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby xsolara33x » Fri May 13, 2005 10:55 am
^^^^ that's only good if you are in socal, he not shipping out...
raphael
xsolara33x
Postby s15lara » Fri May 13, 2005 11:12 am
which ones would you guys reccomend? the trd rsb or the whiteline? im looking to get one and was wondering which would be better. and where can i get them for cheap?
s15lara
Postby StockSolara » Fri May 13, 2005 11:15 am
2000 Lexus GS400
StockSolara
Postby Jon11582 » Fri May 13, 2005 2:13 pm
I got mine from Eddie over at Kinderhook, good guy and he used to be a member here (Gen4 Camry owner I think)
http://www.kinderhooktoyota.com/trd.htm
$150 shipped new
I recommend TRD since you can run it stiffer, has two settings, and Ive heard about more squeaking issues with the whiteline than the TRD.
Jon11582
Postby MentatGom » Fri May 13, 2005 2:31 pm
Hey SleeperSolara,
The Whiteline rear sway bar is a 20mm fixed rate.
Part number is BTR39.
You can order from www.185performance.com or www.globalperformanceparts.com/
I got my Whiteline sets (BTF38 [24mm], BTR39 [20mm]) for $284 shipped from 185.
Installed on a Gen 4 Camry and a Lexus ES300.
The TRD rear sway bar is 19mm adjustable rate.
So you get 19mm street setting or about 21mm on track setting.
Just for additional information Addco and Intrax (22mm front / 19mm rear) also make sway bar sets for the Gen 4 Camry / Gen 1 Solara.
Gom
MentatGom
Postby 1st Gen Sol » Fri May 13, 2005 3:27 pm
I got the TRD rear sway bar set on track track settings and prefer this over the Whiteline rear sway bar because you can adjust between street & track settings.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby cdssolara » Fri May 13, 2005 6:23 pm
I don't think it's a question of which one is better, as they're both good quality. It really depends on what kind of handling balance you want. With the stock front bar, either one is fine. As others have said, the TRD is nice because you can adjust the settings. If you go for a thicker front sway bar, then I'd recommend getting the TRD rear bar and putting in on TRACK setting. Both bars will eventually squeak.
solara_supra_hopeful wrote:which ones would you guys reccomend? the trd rsb or the whiteline? im looking to get one and was wondering which would be better. and where can i get them for cheap?
cdssolara
Postby SleeperSolara » Fri May 13, 2005 7:23 pm
Thanks for the info guys.
I thought the WhiteLine was thicker, but i guess was wrong.
I guess i will get the TRD RSB.
Postby SleeperSolara » Tue May 24, 2005 11:53 am
So the WhiteLine is not adjustiable.
And the TRD is adjustable, i'm assumin'
Postby RichD978 » Tue May 24, 2005 12:03 pm
^^ yup
RichD978
Users browsing this forum: Google [Bot] and 72 guests
