SolaraGuy.com • View topic - Need help choosing drag radials for 15" rims
Postby trd4life » Fri May 13, 2005 4:31 pm
Trying to figure out what the widest tire i can run is on my 2000 camry. Its dropped on trd springs with tokicos. The wheels i will be using are 15x7.5 with a 35mm offset. Whats the widest tire i can run? i was looking at the new hoosier drag radials in 245/60/15, think they would rub?
thanks
Postby Fletch » Mon May 16, 2005 4:28 am
Fronts only, right? I think it will probably stick out past the fender a little but it may not rub unless you are really bouncing around. If those wheels are for drag only, probably worth a shot.
One of my good buddies is a sales rep at tire rack. He won't be able to tell you if it rubs or not but can sell you the tires.
shaun@tirerack.com, (800) 428-8355 ext. 661
2006 Legacy GT spec.B
Fletch
