SolaraGuy.com • View topic - Jim's Fuel upgrade - NO MORE HELP NEEDED, THANKS
Postby that1mexguy » Mon May 23, 2005 12:26 pm
Hey guys, well this morning I started to put it in... it sure to helps to have the right tools LOL so after a few trips to the store and getting everything in place, I started out the car (it starts - yaaaay) but the front fuel rail is leaking a looooot. Instructions say not to over tighten them so I tried not to, but still leaking... did anyone else experience that?? if so, did any of you used anything else to stop the leaking? or should i just keep playing with it til I get it right? I need help quick!!! Pleaaaase!!! thanks guys
that1mexguy
Re: Jim's Fuel upgrade - HELP!!!
Postby SpeedSTARs » Mon May 23, 2005 12:38 pm
that1mexguy wrote:Hey guys, well this morning I started to put it in... it sure to helps to have the right tools LOL so after a few trips to the store and getting everything in place, I started out the car (it starts - yaaaay) but the front fuel rail is leaking a looooot. Instructions say not to over tighten them so I tried not to, but still leaking... did anyone else experience that?? if so, did any of you used anything else to stop the leaking? or should i just keep playing with it til I get it right? I need help quick!!! Pleaaaase!!! thanks guys
Hey Bro,
I just ended up tightening the AN-16 a little more to solve the problem. See if that helps. :wink:
Good luck man. :P
-G
SpeedSTARs
Postby arch.HI » Mon May 23, 2005 1:00 pm
Did you use the sealing washers?
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby that1mexguy » Mon May 23, 2005 1:02 pm
yeah man, it did... i guess i just panic too quick but man, that gas was pouuuuuuring and i freaked out.. i had to put a few rags right under it to absorb the gas and as it leaked, i tighten it up a little more ... at 1st it seemed to leak a bit more but then it stopped. I turned the car on again and i didnt see any leak but i watched it for like 5 mins LOL anyway .. i took a bunch of pics so i'll try to write up a tutorial with pics since i was not able to find one. The instructions provided are good, but until today, i had no idea what the fuel rails were, etc, so i figured with pics it should be a whole lot easier .. and yeah, 30 mins my @$$, took me hooooours!!!! LOL (of course next time i do it, it should take me 30-60 mins LOL)
taking out for a test drive...!!!
:drinking:
that1mexguy
Postby xavier » Mon May 23, 2005 1:50 pm
and what exactly does this help?
xavier
Postby 1st Gen Sol » Mon May 23, 2005 1:58 pm
wonder if this would benefit a 4 cylinder and if its compatible ? ? ? ?
Hook us up with some pics bro..........
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby that1mexguy » Mon May 23, 2005 2:48 pm
xavier wrote:and what exactly does this help?
oh man, there is a whole topic on this but here, just so u know how it all began ..... http://www.camryman.org/forum/viewtopic ... 2d65167493
that1mexguy
Postby arch.HI » Mon May 23, 2005 3:22 pm
An even, and greater quantity, fuel distribution from the fuel filter to the front and rear fuel rails.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby Sleeper » Mon May 23, 2005 6:10 pm
How does one go about getting a upgraded fuel rail????
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby xavier » Tue May 24, 2005 5:18 am
Ahh...so this would only benefit someone running more than the stock hp as the stock fuel rails provide adequate fuel for stock numbers?
xavier
Postby StockSolara » Tue May 24, 2005 10:39 am
xavier wrote:Ahh...so this would only benefit someone running more than the stock hp as the stock fuel rails provide adequate fuel for stock numbers?
fa sho
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Users browsing this forum: Google [Bot] and 72 guests
