SolaraGuy.com • View topic - Blown Knock Sensor
Blown Knock Sensor
Blown Knock Sensor
Postby Paladin06Greg » Tue May 24, 2005 6:36 am
I've never blown one so can someone tell me the indications are? Please be specific.
Thx
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Fletch » Tue May 24, 2005 6:47 am
Feels like you are dragging an anchor. Seriously, the car barely accelerates because the timing is so retarded. I could usually get the code to go to history with an ignition cycle, but as soon as I got on it a little, it would become current again.
The CEL would illuminate a few seconds or so after the car went into safe mode though.
2006 Legacy GT spec.B
Fletch
Postby SC V6 » Tue May 24, 2005 7:35 am
basically cut power even if you were flooring it..
SC V6
Postby that1mexguy » Tue May 24, 2005 8:14 am
oh oh .. what did you do now??? :roll: lol
that1mexguy
Postby SpeedSTARs » Tue May 24, 2005 8:36 am
The symthems are heavy hesitation to the point where the engine sounds and feels like its going to stall out. It goes into the state of mind where the ECU thinks that the running to lean; therefore, the ECU dials back the timing to match the extra air thats being dumped into the engine. It basiclly doesn't know how much fuel and air to mix. IMO, its quite dangerous to be driving in this condition on the freeway. Also, this harms the Cats (exhaust). Hey guys, correct me if I'm off. :D
"O" yah, Blah, blah, yata, yota... :P
SpeedSTARs
Postby Paladin06Greg » Tue May 24, 2005 9:17 am
Nope, I had a friend hook up the OBD tool and it's clean!! Got to me something mechanical in the fuel delivery system. That should be easy to isolate.
I'll check the fuel pressure at the rail.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Yanks0114 » Sat May 28, 2005 10:14 pm
When i blew my knock sensor 1st and 2nd gear will almost like normal
It was 3rd gear that barely even moved
