SolaraGuy.com • View topic - Scan Tool Programs
Scan Tool Programs
Scan Tool Programs
Postby SC V6 » Fri May 27, 2005 1:42 pm
I was wondeirng if anyone had this specific program for running a Scan tool on their computer.. cause I was thinking about getting the program but wanted to see if it was worth it first.. .
It's Proscan
http://www.myscantool.com/
SC V6
Re: Scan Tool Programs
Postby shidosha01 » Fri May 27, 2005 9:05 pm
SC V6 wrote:I was wondeirng if anyone had this specific program for running a Scan tool on their computer.. cause I was thinking about getting the program but wanted to see if it was worth it first.. .
It's Proscan
Hmm...
Nice find! I'm currently using another OBDII scan tool I use from my laptop. It's no where near as nice and user friendly as this Proscan appears to be.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby JoeB » Sat May 28, 2005 5:01 am
Scott, I started reading that info from that web site and was saying, "shoot, is it time to buy a 3rd scanner!" :lol: . DON'T BUY IT! Although the feaures look great and the interface looks nice to use, it is dependant on the ELM hardware interface. I bought the Digimoto scanner which also uses the ELM hardware interface and it's terribly slow talking to the computer. It's SO BAD that it makes any real-time usage like tuning completely imposible! I thought it was just a problem with the unit I had until I started doing some investigation. It turns out it is a known limitation to that setup. My advice when selecting an OBD2 scanner is look at the requirements, if it uses a ELM hardware interface, FORGET IT!
To be more specific, I could only get data at about 1 parameter/second. Lets say you wanted to look at timing. You want to record RPM, Timing and Speed. 3 parameters means you would only get 5 timing samples on a 15 second run. 5 data points accross your 1/4 mile run is worthless! The Car Code scanner I use has a MUCH more cryptic interface. I've begrudgingly got accustomed to using it and still probably can't use it to its potential but it is MUCH faster! It records at like 5 samples per second (I think). I still don't get as many data points as I would like but it is usable. I tried to use the dyno feature on the Digimot - ELM based unit, imagine a dyno run - 1 gear (2nd) only lasts a few seconds so you only get like 3 data points on your dyno!
JoeB
Postby SC V6 » Sat May 28, 2005 7:50 am
So its the Elm setup that makes the whole thing lag.. not the actual program itself? Cause I already have an elm scan reader for my car, which I bought over 2 years ago, but I am going to buy a setup to read codes off my truck 2... so I wasn't sure what to do
SC V6
Postby JoeB » Sat May 28, 2005 2:00 pm
If you already have the ELM hardware, and are ok with it, you should contact them and inquire about a software only purchase. The ELM hardware is $100. My bet is they sell you the software license for $50. That's the way Digimoto does it. The software does look good, it's the ELM hardware that sucks. -JoeB
JoeB
Users browsing this forum: No registered users and 121 guests
