SolaraGuy.com • View topic - shift knobs and e-brake handles
Postby Grnarowana » Mon Jun 06, 2005 11:14 am
Does anyone know if it is possible to change the e-brake handle and shift knbos? The stock shift knob seems to be undetachable and the e-brake handle seems to be like this also. I'm trying the get some wood trim accessories on em.
Help.
Thanks
Grnarowana
Postby Rookie Solara » Mon Jun 06, 2005 12:19 pm
I know the E-brake handle, you have to CUT OPEN the leather/plastic part in order to slide the new E-brake handle in.......not a plug and play thing, and it is point of no return thingy as well......(I would stay away from that unless you have a good speed shop behind you to correct the problem if there is one...)
TRD Stage 3 and sway bar
Ground control Coilover kits
Koenig Tantrum 18x7.5
Apexi N1 exhaust
Apexi S-AFC air fuel controller
Rookie Solara
Postby Hsakuragi » Mon Jun 06, 2005 1:37 pm
u have stick or auto knob?
Hsakuragi
Postby Grnarowana » Mon Jun 06, 2005 5:47 pm
stick
Grnarowana
Users browsing this forum: No registered users and 117 guests
