SolaraGuy.com • View topic - aftermarket brakes. PLEASE HELP!!!
Postby 209solara » Tue Jun 07, 2005 11:16 pm
looking for new rotors. are the ones on ebay worth it, where did you get yours at. slotted + drilled = how much and where for reputable brakes. thanks in advance. ebay = ghetto made??
209solara
Postby Hsakuragi » Tue Jun 07, 2005 11:48 pm
tirerack
Hsakuragi
Postby ChargedSolara » Wed Jun 08, 2005 1:40 am
do a search..thers lot of info on what type of brakes to choose..i went with brembo blanks to be safe, with axxis metal master pads, they stop pretty well
stainless steel braided lines will help eliminate the squishy feel..they should be readily available,
2008 C6 LS3
ChargedSolara
Postby that1mexguy » Wed Jun 08, 2005 3:47 am
I just got a set of Brembo cross/drilled rotors and stainless steel brake lines from sportbrakes.com for $300. The site is not working much so you have to call the guy, ask for Ras and tell him you saw his banner at seloc.net
that1mexguy
Postby Fletch » Wed Jun 08, 2005 6:43 am
Call Shaun at tirerack, 800 428-8355 ext. 661. They just got some new brake products in that might not be on the website yet.
2006 Legacy GT spec.B
Fletch
Postby Rookie Solara » Wed Jun 08, 2005 7:29 am
For you information about brake selection on EBAY, they are not all Getto style brake system.....a lot of them are legit BREMBO cross drill brakes, and they are probably one of the best that you can get for less then $200 for all 4 corners....
Of course, I don't think you can get anything wrong from Tirerack, but BRAKES are very important part of your car, so, please spend some time on your research and ask a lot of questions..........
TRD Stage 3 and sway bar
Ground control Coilover kits
Koenig Tantrum 18x7.5
Apexi N1 exhaust
Apexi S-AFC air fuel controller
Rookie Solara
Postby SleeperSolara » Wed Jun 08, 2005 4:11 pm
Yeah Brembo is the only one i think.
Unless you got big rims then you can go wit Rotora.
