SolaraGuy.com • View topic - body kit help
body kit help
body kit help
Postby Dawgz » Wed Jun 15, 2005 11:44 pm
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=36475
wats the negative side of gettn that? and positive side? anyone have that kit? would i be able to use my fogs still?
Postby RichD978 » Thu Jun 16, 2005 5:13 am
negative sides:
ugly
breakable
hella ugly
price for installation/fitting/paint
positive sides:
price you pay for kit
doubt the fogs would fit
RichD978
Postby Astro » Thu Jun 16, 2005 9:05 am
positive- I love the look.
negative- Cost a lot to put on and it cracks very easily. If you are lowered, it's a real b*tch getting around.
Postby TadS » Thu Jun 16, 2005 2:54 pm
Positive: Different than the group think, everybody else has it, completely played out kit.
Negative: Expensive installation, you have to be very careful with it or it will get more expensive.
You will be able to use the fog switch and wiring, but probably not the housings without custom fiberglass.
TadS
Postby krawzyazn » Thu Jun 16, 2005 2:56 pm
love the molded body though
Postby 562solara02 » Thu Jun 16, 2005 7:08 pm
pos=different, cheap and still looks good
neg=got to get the rear molded on and its an old style
i was thinking about that kit when i was going to flare out my ride
Image<--- MY CAR ALARM
562solara02
Postby udonoogen » Thu Jun 16, 2005 7:15 pm
$210 to ship? ouch!!!
udonoogen
Postby JoeB » Fri Jun 17, 2005 5:19 am
Positive: I think it looks good, at least more aggressive but like said before, it's played out. There are just too many that look like that. Initial cost is attractive but don't let that fool you.
Negative: Although the initial cost is low, most of those kits show up with thin spots, bad spots and need to be worked before installation. Additionally, There is no bumper support so they flap in the wind. Just the flapping alone damages the paint. Any little bump and that cheap fiberglass is cracked. It really needs to be molded into the car for a good installation. All of the workmanship to get it installed is very expensive not to mention all the touchup to follow...
I'd still love to find a nice aggressive urethane kit... -JoeB
JoeB
Postby Astro » Fri Jun 17, 2005 9:03 am
BTW...your stock fogs will NOT fit in the openings. You'll have to buy some fogs from a 98+ GS300. On a side note, this being my 2nd front bumper, the GS fogs don't fit correctly. The opening is longer and a bit taller. I've been thinking of using fogs from 89-95 5 series(E 34), but would have to do some re-wiring.
