SolaraGuy.com • View topic - Is it worth it to supercharge a solara?
Postby Grnarowana » Thu Jun 16, 2005 7:12 pm
Besides the speed. What else can a S/C do for a solara or even the driver? Yea, it can probably give you some G-force and pull your neck back a bit. But is it worth it?
Do you still get good mileage?
Does it hurt the engine?
Is it worth the money?
How come people use TRD superchragers or other, but i never hear about VORTEC superchargers, WUTS UP? Doesn't fit?
Grnarowana
Re: Is it worth it to supercharge a solara?
Postby SleeperSolara » Thu Jun 16, 2005 7:27 pm
Grnarowana wrote:Besides the speed. What else can a S/C do for a solara or even the driver? Yea, it can probably give you some G-force and pull your neck back a bit. But is it worth it?
Correct my friend only TRD makes a S/C for our cars.
About the same MPGs if you don't gun it everytime.
And yeah it worth it.
Postby cdssolara » Thu Jun 16, 2005 9:44 pm
When you're trying to figure out if the supercharger is worth the cost, keep in mind that you're probably going to want other mods to maximize the benefits of the s/c. You'll probably want to get a more free-flowing exhaust system, a fuel controller, etc. If you get really addicted, you'll want headers, new injectors, smaller pulleys, and additional fuel mods. The supercharger by itself is OK, especially if you have a 5 speed, but it's the other stuff that really makes it fun. That "other stuff" can easily double the cost.
cdssolara
Postby lazyboyz69 » Thu Jun 16, 2005 11:10 pm
yea i have a smaller pulley and you can really feel the gforce in second gear better than a wrx...my bro has a wrx w/mods doesn't pull like the solara....
lazyboyz69
Postby TRD MCV20L » Fri Jun 17, 2005 2:18 am
cdssolara wrote:When you're trying to figure out if the supercharger is worth the cost, keep in mind that you're probably going to want other mods to maximize the benefits of the s/c. You'll probably want to get a more free-flowing exhaust system, a fuel controller, etc. If you get really addicted, you'll want headers, new injectors, smaller pulleys, and additional fuel mods. The supercharger by itself is OK, especially if you have a 5 speed, but it's the other stuff that really makes it fun. That "other stuff" can easily double the cost.
very well said :D
TRD MCV20L
Postby Fletch » Fri Jun 17, 2005 4:27 am
It has been worth it. Gas mileage is not really affected, even when I'm getting on it all the time around town, I still get around 18mpg.
The TRD S/C is made by Kazuma, which is really an Eaton roots blower, basically similar to the type of S/C on a GTP, which has been an OE production part for several years. They S/C'ers are tried and true and require little to no maintenance. I think Vortec tends to make centrifugal S/C'ers which would require a custom set-up for the 1mz-fe.
If you are really going to do it, it would behoove you to get plugs, injectors and Jim's fuel upgrade installed simulaneously.
2006 Legacy GT spec.B
Fletch
