SolaraGuy.com • View topic - 190 Walbro Fuel Pump Installation Question - Help pls!
Postby that1mexguy » Sat Jun 18, 2005 8:07 pm
OK so I just finished installed the new fuel pump. Everything went smooth, except for when I had to put it back into the car. It seems that new filter is a bit bigger so it was touching at the bottom of the tank and my fear is that it wasnt going to get a good seal. Still, I screwed everything back in place and successfully took the car out for a spin. I cheked for leaks and I didnt smell any fumes, so I think it sealed properly, and then I also removed the gas tank cap and felt some pressure released, so that only tells me that the cover for the fuel pump is properly sealed, but my only concern now is that the bottom of the new filter is pretty much at the bottom of the tank squeezed and I wonder if that is good or not or should I even be concerened. Did any of you experienced anything like this?? Thanks in advance for your assistance.
that1mexguy
Postby that1mexguy » Mon Jun 20, 2005 9:18 am
Thanks for the overwhelming response, I guess this one I'll have to wait and see if my car dies on me or not, anyway.... on to another question, for those of you that have this pump installed, is it supposed to be louder than the stock pump?
that1mexguy
Postby arch.HI » Mon Jun 20, 2005 10:43 am
I have the pump, just not installed yet. I've had it for months but I've just been lazy. But yes it is louder than stock.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby lazyboyz69 » Mon Jun 20, 2005 12:12 pm
your fine that1mexguy, it suppose to be louder... i installed the same thing in my car no problems yet i worried that i didn't seal it right 2, but i guess i did...
lazyboyz69
Postby wiz2 » Mon Jun 20, 2005 8:40 pm
What he said. Sounds like alternator whine all the time. I dont mind it all !! If someone really knows cars they know whats up when your at a stoplight!
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby StockSolara » Mon Jun 20, 2005 9:16 pm
wiz2 wrote:^^^^^
fa sho
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby shidosha01 » Wed Jun 22, 2005 6:04 am
Did you try shaving the pieces of the housing so the pump can slide all the way in? I remember having that problem before and after shaving it a bit it solved the problem.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
