SolaraGuy.com • View topic - Stainless Steel brake lines
Postby that1mexguy » Mon Jun 20, 2005 11:20 am
I'm hoping to get mine installed this weekend. I'd like to do it myself and from what I've seen, it should be a fairly easy job. Just wanted to know if any of you guys have installed your lines yourself and how hard/easy was it. Any pointers? or do you recommend i get it done by a shop ... thanks in advance!
PS. there is no tutorial on this, and doing a search on brake lines will come back with everything, except what I need to know, thanks.
that1mexguy
Postby TadS » Mon Jun 20, 2005 3:38 pm
It's very easy; just remember to use the proper flair wrench. Make sure you do a good job bleeding the brakes, and you should be in good shape.
TadS
