SolaraGuy.com • View topic - whats the deal on h-tech's?
Postby captainpimp » Thu Jun 30, 2005 5:33 pm
are these actually going to come out or not? need to drop this biatch and im getting tired of waiting. for those with s-techs or vogtland, which spring sags less over time? i really dont want to have to worry alot about scraping the ground.
brian
captainpimp
Postby captainpimp » Sat Jul 02, 2005 7:17 pm
bueller, bueller?
captainpimp
Postby StockSolara » Sun Jul 03, 2005 1:23 pm
I have the Eibach Pro Kit w/ Tokico Struts and I barely scrape unless you go hella fast over bumps or up driveways. . . You shouldn't even going that fast up and over those things anyways. . . Just get some springs cause those 1 inch drops don't do much unless your car is already HELLA low to begin with
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby 1st Gen Sol » Mon Jul 04, 2005 9:11 am
Hows the ride on the Eibach Pro Kit w/ Tokico Struts setup ? ?........and how low does it drop your ryde in the front and rear, last I read up on them, they were 1.4 inches all around .
I wanna go with the Tokico Blues w/ Tein H-tech setup if they ever come out b/c I don't want a drastic drop. Only looking for something to decrease the space in the wheel well to a minimal but not excessive and thats my reasoning towards waiting for the H-techs to come out.
My cousin has a set of H-techs on his TL-S and its not a crazy drop but a moderate drop where the front is 1.4 and the rear is 1.0.
.......Hopefully these come out soon, if not I might just end up getting the same setup as you or with a pair of Tein S-tech springs.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby captainpimp » Mon Jul 04, 2005 12:27 pm
from what i have found there is no h-tceh setup for solara. if they dont have one by now i assume they never will.
1 gen sol - since you are looking for springs too this is what i have found.
vogtland - 1.5 all around
s tech - 1.65 front/1.42 rear
eibach - 1.6 front and rear
i havent seen any dropped solaras in person but i assume by the measurements an s-tech drop will look the best. and its the cheapest.
i think i will just by s-techs.
brian
captainpimp
Postby StockSolara » Mon Jul 04, 2005 2:00 pm
1st Gen Sol wrote:Hows the ride on the Eibach Pro Kit w/ Tokico Struts setup ? ?........and how low does it drop your ryde in the front and rear, last I read up on them, they were 1.4 inches all around .
Eibach are 1.6 all around and the ride quality is awesome. . . It is stiffer than stock but not bumpy unless your just going to lower with stock struts but with the Tokicos they feel great
2000 Lexus GS400
StockSolara
solution
Postby solow1605 » Mon Jul 04, 2005 5:16 pm
Dude just fill your car up with 3 fat bitches that way you dont have to lower your car and it will look lowered. Then tell them to lay low so no one sees them. Problem solved.
2003 Anniversary Edition z06. Black on black...seeexxy
solow1605
Postby RichD978 » Mon Jul 04, 2005 5:36 pm
tried it... rubs like a biatch tho
RichD978
Re: solution
Postby 1st Gen Sol » Mon Jul 04, 2005 8:30 pm
solow1605 wrote:Dude just fill your car up with 3 fat bitches that way you dont have to lower your car and it will look lowered. Then tell them to lay low so no one sees them. Problem solved.
^^^^ thats aight, I don't want my ryde smelling of Kentucky Fried Chicken along with grease stains everywhere.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Users browsing this forum: Google [Bot] and 48 guests
