SolaraGuy.com • View topic - SuperPro Polyurethane Dogbone Bushings UPDATE Pics Added #2
Postby Paladin06Greg » Mon Jul 04, 2005 8:48 pm
Here are some pics of the dogbone with the SuperPro bushings. Install pics included.
This one shows the old bone with the new bone installed.
A good shot of the large end which is 65mm for us auto tranny guys.
Hello All,
Yes, I know I told you I would be gone for a while due to matters of a personal nature but, we ( the Solara Community) really need this modification and the good folks at SuperPro have come through for us.
Please see their e-mail below from Down Under and get ready to be excited!
Some words from "Down Under"
The SuperPro bushing has been designed to reduce the amount of engine movement under load. (I.e. acceleration/deceleration.)
This part will reduce the movement by approximately 55% when compared to a new OEM rubber sample.
We have incorporated "SuperPro Turbo" style voiding which allows this improvement, without inducing excessive noise or vibration into the vehicle. Any high frequency vibration is absorbed by the turbo pattern.
As the actual dog bone arm is easily removed from the vehicle, and has to be, for the removal of the original bushing, we have designed the new part as a one-piece cotton-reel style. Although it may be a little harder to install initially, the cotton-reel style allows the features above
to be incorporated. It also, is then self-contained in the arm, (i.e. can not squash out)
A hydraulic press is required to remove the OEM part, of this same part. It can also be used to press the new SuperPro part into place. If a hydraulic press is not available... the new part can pressed into place with a large bench vice, a G-Clamp or drawn into place with a section of threaded rod and large washers.
Once sample parts are test fitted / driven and approved by Greg (Paladin06) the part number will be, SPF2706K x 1 (enough bushes in kit to complete both ends of the Dog Bone Mount) Large end of Dog Bone mount 65mm inside diameter. Greg has assured us he will test drive and report to us ASAP!
FYI - If your vehicle has, "Large end of Dog Bone mount 50mm inside diameter you need to order part number SPF1348K x 1
(again, one kit has enough bushes to complete both ends of the Dog Bone Mount)
Greg has provided the vehicles that these bushings are applicable too. If in doubt, see Greg's earlier post or contact Greg at paladin06@comcast.net.
Please contact our USA SuperPro distributor for your closest stock in your area. See their details on www.superpropoly.com.
Last edited by Paladin06Greg on Tue Jul 05, 2005 12:28 pm, edited 2 times in total.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby StockSolara » Mon Jul 04, 2005 11:22 pm
So is this part going to be a brand new dogbone so you don't need to push out the old bushings?
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Paladin06Greg » Tue Jul 05, 2005 12:51 am
For the community bushings only!!!
StockSolara wrote:So is this part going to be a brand new dogbone so you don't need to push out the old bushings?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby StockSolara » Tue Jul 05, 2005 4:26 am
How much?
2000 Lexus GS400
StockSolara
Postby Paladin06Greg » Tue Jul 05, 2005 1:37 pm
Updated initial post with pics..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Tue Jul 05, 2005 2:03 pm
hmmm... I would have to order the larger one right:? since origionally I was an auto? how much and when can we order?
SC V6
Postby shidosha01 » Tue Jul 05, 2005 6:20 pm
Nice one Greg. Did you happen to send out the rear stock motor mount to Australia? If not, I plan to have Super Pro make one for that section too. If you did already. Thanks.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby SleeperSolara » Tue Jul 05, 2005 8:15 pm
yeah, finally.
I the next mod for me.
Postby Paladin06Greg » Wed Jul 06, 2005 9:22 am
Good Day Gentlemen,
I had the opportunity to test drive my car today (no rain in sight) and I must say I'm very impressed with the prototype SuperPro dogbone bushings. These are a must have for all Solara owners. Two things are immediately noticeable:
1. There is a noticeable positive improvement in the throttle response. When I applied power I felt it immediately and with authority.
2. There is also a noticeable positive improvement in the transmission shifting under hard acceleration and normal driving conditions. This improvement can be felt when the transmissions shifts up or down. The shifting feels more firm and with authority.
I noted no indication of bushing slippage or damage after my 165 mile highway test drive!! That's more miles then I drive in two months but....
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Wed Jul 06, 2005 10:07 am
sounds good here.. im ready to order and install
SC V6
Postby thakidd » Wed Jul 06, 2005 12:59 pm
sounds awsome greg,let us know when we could order....
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby OKANG » Wed Jul 06, 2005 1:13 pm
Same here. Let us know when we can order :)
Cogito Ergo Zoom
OKANG
Postby Paladin06Greg » Wed Jul 06, 2005 1:24 pm
I have requested pricing and availability!! I'll let you know soon..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SpeedSTARs » Wed Jul 06, 2005 1:32 pm
thakidd wrote:sounds awsome greg,let us know when we could order....
Me three on pricing and availability. :D
Paladin06Greg Posted: Wed Jul 06, 2005 4:24 pm Post subject:
I have request pricing and availability!! I'let you know soon..
Awesome. :P
SpeedSTARs
Postby StockSolara » Wed Jul 06, 2005 3:14 pm
This is going to be awesome
2000 Lexus GS400
StockSolara
