SolaraGuy.com • View topic - could it happen?
could it happen?
could it happen?
Postby returnofthedack » Tue Jul 05, 2005 12:30 pm
before i put my supercharger on, this idea came into my head. could it be possible for a n/a 1mz to get more than 200 at the wheels? i'd like to accomplish this before i slap on the blower.
www.seandackermann.com
The only person that can stop you in life, is yourself
returnofthedack
Postby Turbosolara » Tue Jul 05, 2005 1:15 pm
most likely no, unless you NOS it. It is because lack of aftermarket part support. (you would have to raise the compression in order to gain NA power)
Postby StockSolara » Tue Jul 05, 2005 1:34 pm
Turbosolara wrote:most likely no, unless you NOS it. It is because lack of aftermarket part support. (you would have to raise the compression in order to gain NA power)
fa sho
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby TadS » Tue Jul 05, 2005 1:54 pm
I think it's very doable for a 1MZ to get to 200fwhp, but it wouldn't be that cheap to do. Really, you could probably find the power in the head alone with a port and polish, oversized valves, upgraded springs, retainers, some customed up camshafts, etc. Flatlander has a kit for larger displacement pistons and higher compressions. This stuff would cost you a pile of money even if you did all the install work yourself though, so while I think it is doable, I would just get the blower and build that way.
Also, I am not sure, but I don't think it's a good idea to raise your compression and then get forced induction. So, in that regard it's complicated.
TadS
Postby Astro » Tue Jul 05, 2005 3:11 pm
TadS wrote:Also, I am not sure, but I don't think it's a good idea to raise your compression and then get forced induction. So, in that regard it's complicated.
You definately don't want to raise compression when adding a charger.
Postby Hsakuragi » Tue Jul 05, 2005 3:57 pm
that will cost more than just adding a charger
Hsakuragi
