SolaraGuy.com • View topic - Thinking about a short shifter
Postby Grnarowana » Thu Jul 14, 2005 8:35 pm
I was thinking and look for a TWM or TRD shortshifter, but my buddy suggessted any generic shortshifter will do since he doesn't have a brand name shotshifter for his subaru. Does it work?
Grnarowana
Postby thealkimo » Thu Jul 14, 2005 9:25 pm
i'm pretty sure it's gotta be application specific...
trd and twm are the only suppliers for the solara...
thealkimo
Postby Fletch » Fri Jul 15, 2005 4:08 am
Think no more, do. A few of my VW buddies with short shifters have complemented the feel and throw of my shifter.
2006 Legacy GT spec.B
Fletch
Postby Mole » Fri Jul 15, 2005 8:49 am
Post in the correct forums
Postby Monkeyman » Fri Jul 15, 2005 11:09 am
I have had both the TRD and TWM shifters, and the TWM has a much shorter throw. In terms of "generic" VS. "Brand Name" every shifter is different because every car is different and even cars that are the same can have different transmissions, so the shifter for each is different. The TWM is pretty cheap and works well, just make sure you use a low shift knob, other wise you defeat the purpose of installing the short shifter.
Go with the TWM.
Monkeyman
Postby thealkimo » Fri Jul 15, 2005 11:12 am
i have the trd one and may eventually switch to a twm just because the trd one sits almost as high as the stock one...
either way, a short shifter is good bang for the buck...
thealkimo
Postby kilade » Mon Jul 18, 2005 7:35 pm
newbie here. what exactly does a short shifter do?
kilade
Users browsing this forum: Google [Bot] and 47 guests
