SolaraGuy.com • View topic - Replacing Stock Struts...
Postby dbanker » Thu Dec 12, 2002 3:47 pm
My 99' Solara has about 65,000 miles on it and needs its stock struts replaced. I enjoyed the ride they provided but wouldn't mind adding a LITTLE more stiffness on them. Does anyone have any advice as to which struts would be a good choice withought having to worry about switching the springs with it? I'm looking for something that is high quality and an upgrade on the stock struts. Thanks!
dbanker
Postby cdssolara » Thu Dec 12, 2002 5:23 pm
If you're going to stick with your stock springs (why?), then look into KYB struts. I think they're just slightly stiffer than stock, and are a good replacement for OE.
cdssolara
Postby TITO » Thu Dec 12, 2002 6:03 pm
I have KYB struts but I added intrax springs, good price and I'm very pleased with this setup. Not to stiff and better handling.
99 V6, LOWERED, COOL CUSTOM GRILL, TINTED WINDOWS, CUSTOM FRONT BUMPER, WHITE 17" WHEELS, BODY KIT, CLEAR CORNERS, INTAKE WITH K&N.
TITO
Postby dbanker » Thu Dec 12, 2002 7:31 pm
Which kind of KYB struts and intrax springs do you have? How does the ride quality differ from what the stock setup was?
dbanker
Postby TITO » Thu Dec 12, 2002 8:49 pm
KYB gas adjust with 1.6" lowering springs. It's a little stiffer than stock, not too much, but handles much better.
TITO
Postby cdssolara » Thu Dec 12, 2002 9:02 pm
dbanker wrote:Which kind of KYB struts and intrax springs do you have? How does the ride quality differ from what the stock setup was?
I would only say to go with the KYB's if you're sticking with stock springs. If you're planning to lower the car, you probably will want some slightly firmer struts. Rather than repeat myself, see my post on your other thread.
cdssolara
Postby dbanker » Thu Dec 12, 2002 11:57 pm
What would be my best option if I wanted to keep my car the same height, but get new struts and springs?
I'd like to keep the ride similar to how it is with maybe a little added firmness. I plan on getting the rear strut assembly to help reduce body roll and improve cornering. I'm not looking to race my car around (although that would be a damn good time), just to improve the performance somewhat while keeping the ride relatively smooth.
dbanker
Postby Flipside909 » Fri Dec 13, 2002 2:47 am
I'm a full advocate of Tokico HP series. :D I have over 20k miles and had them in for more than a year now. Still gives me a good balance of comfort with performance.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby dbanker » Fri Dec 13, 2002 9:59 am
Just checked out the Toxico HP's and they could definitely be an option. How would you describe the ride difference from the stock struts compared to the HP's? How much of the smooth ride do they give up?
Also, what would be some good springs to go with them that wouldn't lower the car at all? Or would these struts work better if they were used with lowering springs? One more thing.....could these struts work with the stock springs sufficiently, or would getting some new one's be a good idea??? thanks-
dbanker
Postby dbanker » Fri Dec 13, 2002 10:09 am
One more question.....I've been looking at some Toxico HP struts and all I've seen are matches for the Camery 97 - 01. Are these the struts you're refering to that will fit a 99 solara?
dbanker
Postby Peter » Fri Dec 13, 2002 10:11 am
i dont see why you dont wanna lower your car, the center of gravity would be lower to the ground therefore giving you better handlight and a lot less roll. but whatever floats your boat. i think it'd be pointless to get new shocks without a set of lowering springs.
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby dbanker » Fri Dec 13, 2002 10:23 am
I wouldn't mind lowering it, and therefore getting better handling, but I also want to minimize as much as possible not sacraficing ride quality. Or could I lower and still get a really good ride? Most of my driving I'd like to just keep the ride smooth.
Most people I've talked to said when you lower, because of the lower center of gravity you'll need a stiffer strut to compensate, and therefore ride quality MUST be stiffer. Part of the reason I got this car was because I enjoyed its ride...
dbanker
Postby Peter » Fri Dec 13, 2002 10:27 am
i have heard from everyone with the eibach/tokico combo say taht the ride quality is still very nice. it will no doubt be stiffer, but not crazy stiff. im installing eibach w/ stock shocks for now and i wonder how my ride will be. i plan on getting tokico's later on. in my opinion, the stock suspension on the solara is a little bouncy, so making it a little stiffer would be perfect
Visit Black Sheep
Peter
Postby dbanker » Fri Dec 13, 2002 10:43 am
I've looked around a bit and it looks like the Toxico HP's run about $400 or so for the set is the best I've seen. How much are those eibach springs that you got? And which ones are you refering to?
I think I've read they're pretty much the same as the TRD's except they both lower around 1.6" or something along those lines.
one more thing...what would be a good guess as to how much it'd be to have struts/springs installed?
dbanker
Postby Peter » Fri Dec 13, 2002 12:21 pm
i dont know anything about install prices cuz i do everything myself...or will.
i got the eibachs for free cuz i made a flyer for my friends shop.
tokico hp? you have a link?
Visit Black Sheep
Peter
