SolaraGuy.com • View topic - Lowering with OEM Gen2 17s. Few questions.
Postby SolDoubt » Tue Aug 02, 2005 7:01 pm
Hey all,
Im in the process of buying tires for Gen 2 stockers. My question is, what do you recommend for tire size to get. Im thinking about 215/40(or 45)/17. I live in New England and i dont plan to swap them out for winter. I was just goin to get all season tires. Any suggestions on what tires to get also?
Also just to make sure I searched and found i needed 5mm spaces for the rear? Is that the correct spacer to get?
Thanks a lot you ppls
Dropped woohoo!
SolDoubt
Postby sleepin2000 » Tue Aug 02, 2005 7:27 pm
I am lowered with Gen 2 stock rims and I use 215/50/17 tires. I have Toyo Proxes TPT and they have been great in dry weather, wet weather, and even snow. Your 5mm spacers will be fine for the rear. Hope this helps you out.
In Memory of My Son
Christian Edward Goldstone
October 13, 2005 - June 7, 2007
sleepin2000
Postby RichD978 » Tue Aug 02, 2005 7:37 pm
which ever tires BJs have a sale on
RichD978
Postby ICrazyChrisI » Tue Aug 02, 2005 7:38 pm
Depends on your suspension. My oem 17s BARELY clear with 15mm spacers.
ICrazyChrisI
Postby SolDoubt » Tue Aug 02, 2005 8:04 pm
I have the Tein/Tokico combo. I was thinking of either gettin the Yokohama ES100 or the Kumho Ecsta ASX anyone have experience with those? The all seasons are already eating my wallet up and the Toyo's seem even more expensive
Dropped woohoo!
SolDoubt
Postby SolDoubt » Tue Aug 02, 2005 8:05 pm
RichD978 wrote:which ever tires BJs have a sale on
one word: chinaman!!!!!!!
Dropped woohoo!
SolDoubt
Re: Lowering with OEM Gen2 17s. Few questions.
Postby PhreakdOut » Tue Aug 02, 2005 8:24 pm
SolDoubt wrote:Hey all,
I also have a lowered Gen2 and live in the Detroit area.
I went with a wider tire but kept the same circumference. OE = 215/55/R17 --> New Tire = 235/50R17.
The fit is good on the OE wheels and the tread width is about 1" wider on Firestone Firehawk LH's. I chose this tire for the tread pattern to help with winter performance and wet traction. Had I selected a summer tire, the traction would be similar to a mad tabby cat on a shag carpet.
I did not need any spacers. However, there's still room between the tire and fender if you need / want to use them.
Postby 1st Gen Sol » Tue Aug 02, 2005 9:05 pm
^^^^ ahha..........thats funny
I'd go with the Kumho's, but I'd be careful with them in the winter, my boy got a set he he slides through each line on the road before coming to a complete stop.
......on a side note, imma be round the way August 20th or so, should roll by and chill.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby SolDoubt » Tue Aug 02, 2005 9:42 pm
ya jeff sounds good, hopefully by then i will have everything on my car.
Dropped woohoo!
SolDoubt
Postby 1st Gen Sol » Tue Aug 02, 2005 10:03 pm
Coo, good luck with what you go with..... 8)
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby RichD978 » Wed Aug 03, 2005 6:52 am
Y u gotta be racist for?!?
RichD978
Postby Jon11582 » Wed Aug 03, 2005 7:07 am
My Kumho 716 HP4 GTAS (Grand Touring All Seasons) are awesome in the winter, except when theres over about 3 inches of snow. Its still way better than stock, but maybe everything is - Ive never owned any other AS tires other than these and stock.
And I dont know....15mm spacer sounds like alot...thats a pretty thick spacer. How many turns to tighten on the lugs with that much spaced out?
2000 Black Solara SE
Jon11582
Postby Hsakuragi » Wed Aug 03, 2005 8:13 am
i 2nd that :x
Hsakuragi
Postby SolDoubt » Wed Aug 03, 2005 8:19 am
i 3rd that since im chinese :-? jp rich u donkey
I just bought the wheels off a ex-SG guy and he told me to get these hub-centric wheel spacers because over the long run it would put a lot of strain on the lugs. He mentioned that H&R makes them? anyone have any more info on this?
Dropped woohoo!
SolDoubt
Gen 2 Rims
Postby SLOW-ARA » Wed Aug 03, 2005 8:44 am
I was wondering if you are putting these gen 2 rims on a gen 1.... I was thinking about doing this since it is an inexpensive wheel upgrade.
SLOW-ARA
Users browsing this forum: No registered users and 109 guests
