SolaraGuy.com • View topic - Toyo Proxes 4.. comments
Postby SC V6 » Wed Aug 03, 2005 8:45 pm
I am looking into new tires since mine are about to the wires... anyone have these tires? I've got stock wheels, and looking for a good performance tire that isn't going to cost an arm and a leg.. looking to spend 150/tire or less
SC V6
Postby ThatVietGuy » Wed Aug 03, 2005 9:07 pm
http://www.discounttiredirect.com/direc ... d=16&ar=55
Really good performance, pretty cheap. You just have to downgrade to 205/55 :P
Otherwise ---> http://www.tirerack.com/tires/Compare1. ... &x=34&y=13
I think the Dunlop SP Sport A2 Plus is pretty nice
P.S. I've heard from other people that the Proxes are decent.
ThatVietGuy
Postby lazyboyz69 » Wed Aug 03, 2005 10:31 pm
don't get toyos proxes.... kinda soft tires... i had two of them and they bent my rims but i had 215/40/18 i would go with nitto 555 good tires off the line.... i just got some kumhos 711 for 80 bucks each....225/40/18 not bad for the price
lazyboyz69
Postby SC V6 » Thu Aug 04, 2005 4:25 am
I was going to go w\ a 215/55/16 for my stockers
SC V6
Postby SC V6 » Thu Aug 04, 2005 4:28 am
currently I have Bridgestone Pontenza S-03 Pole positions.. and I have worn the crap out of them
SC V6
Postby NVDIS1 » Thu Aug 04, 2005 5:03 am
i have tha proxes 4 in 19's & love 'em. they handle great :D . i only drive tha ryde on weekends & dry days 2 :D other than that it sits in tha garage covered up :D
http://members.cardomain.com/rgztoy
Postby SC V6 » Thu Aug 04, 2005 8:10 am
same here.. my car is my street pounder.. only comes out when its nice
SC V6
Postby Fletch » Thu Aug 04, 2005 10:50 am
S-O3's and Michelin Pilot Sports are the most common performance tire I see on the cars at the tire-rack events. My buddy works there and has driven on all of the sets. Believe it or not, he likes the performance of the Kuhmo Escta MX's for the money, although they are a little loud.
2006 Legacy GT spec.B
Fletch
Postby Jackass-Jeff » Thu Aug 04, 2005 12:30 pm
SC V6 wrote:currently I have Bridgestone Pontenza S-03 Pole positions.. and I have worn the crap out of them
LOL!! You can't go from S-03 to Proxes 4!
Check out FUZION ZR-i... or was it HR-i? ... well, they have a similar tread pattern to the S-03 (Brig. owns Fuzion... it's their "Scion") and are pretty damn cheap.
I've yet to use them, but they were recommended to me when I was shopping for tires.
225/40R18
Fuzion: $90 each
Proxes 4: $115 each
PZero: $125 each
My tire guy recommended the Fuzion over the PZero!!
1GR-FE ftw!
Jackass-Jeff
Postby SC V6 » Thu Aug 04, 2005 1:30 pm
the wear on the SO3's was horrible.. I went threw those so quick.. its sick
SC V6
Postby Jackass-Jeff » Thu Aug 04, 2005 2:20 pm
SC V6 wrote:the wear on the SO3's was horrible.. I went threw those so quick.. its sick
ultra high performance tires wear lke that... middle of the road ones (that are found as OEM) wear 'normally'
Pirellis are found on Porsches and (higher end) Benz.
1GR-FE ftw!
Jackass-Jeff
Postby Fletch » Fri Aug 05, 2005 3:58 am
I'm currently rolling on 225/40/18 Fuzion ZR-i. They are totally decent for the price. Can't speak to tire wear yet. My only complaint so far is the tread width is a little narrow, noticalbly more than the AVS ES100's I had on previously. If you are planning on 215's on stock wheels, Fuzions would probably be a good fit.
Fletch
