SolaraGuy.com • View topic - Lighting question.
Lighting question.
Lighting question.
Postby SolDoubt » Wed Aug 03, 2005 9:00 pm
So one of my headlights blew or i thought so. But i flipped on the high beams by accident today and the bulb seems to work fine for high beam. What the freak is up wit that i checked the wiring and it still doesnt work on low beam but when i high beam it it works. This is a gen 1 dual filament crap. Anyone know whats up?
Dropped woohoo!
SolDoubt
Postby SpeedSTARs » Wed Aug 03, 2005 9:57 pm
:fadein: Well Bro,
Since the H4 bulb is a dual filament bulb, it has a tendency to blow-out one or the other. Your sure bet is to get a new bulb and see it the new one lights up at the low beam setting. If this doesn't work, check the fuse box that located in from of the battery. There should be an individual fuse for each side of the headlamps. The fuse on the very left should be the DRL (daytime running lamp). See if this helps out. :wink: :angel:
SpeedSTARs
Postby 1st Gen Sol » Wed Aug 03, 2005 10:08 pm
The low beam filament is blown. I would get a replacement bulb and just take out the old one.
I had the same thing happen to me but both my headlights blew at the sametime and it was at night. I ended up driving with just my fog lights running that night.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby SolDoubt » Thu Aug 04, 2005 6:07 am
problem solved ...... HIDs!!!!
Dropped woohoo!
SolDoubt
Postby StockSolara » Thu Aug 04, 2005 11:52 am
SolDoubt wrote:problem solved ...... HIDs!!!!
Nice solution
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SolDoubt » Thu Aug 04, 2005 8:56 pm
holy crap guys i think i broke the knob to adjust the headlight. Its glare city here. Does anyone know if i need to replace the whole headlight just for that knob? Also after i installed the HIDs my fogs went out for some reason. One was already burnt and the other jsut doesnt seem to turn on now either. OMFG :x
Dropped woohoo!
SolDoubt
