SolaraGuy.com • View topic - Help! New wheels...
Help! New wheels...
Help! New wheels...
Postby CASTRO » Fri Aug 05, 2005 11:26 pm
Allright people, the IS300 rims@ 22lbs each is just killing my performance on the track, as well as being a big poopoo to change/swap due to the weight. Any suggestions on the measurements/brands/models for 17inch rims? I need them to be as wide as possible and more importantly extremely light. I was thinking around the lines of ROTA slipstreams as they have a 17x8.5 model, but dont know the offset i should be getting with 8.5width rims. Im currently running 5mm spacers in the rear as the lexus wheels with 215 tires rub. Any suggestions? Its mainly for track use so i might be mounting some fatty grippy tires on it. Can't go smaller than 17 cause of the front supra brakes.
CASTRO
Postby Ford_Fixorrepairdaily » Sat Aug 06, 2005 1:13 am
try motegi trak lite 17" are 15lbs.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby CASTRO » Sat Aug 06, 2005 8:32 am
damn those look nice too. Look I'm going for is the thin spoked rims so I get good brake rotor cooling. Anymore suggestions? I like the weight on those 17x8 rims.
CASTRO
Postby CASTRO » Sat Aug 06, 2005 9:30 am
ive been looking around and I think im sold either on the Motegi or the rota rims. Any place to get them for cheap or actually order them?
CASTRO
Postby Ford_Fixorrepairdaily » Sun Aug 07, 2005 11:47 pm
Back then I tried to get th 19" motegi trak lite at discount tire. But no luck.Because the salesman was a dumbmonkey. Guess what the salesman said. "What do you want them, theyre cheap". I ask why? He said because theyre from Taiwan. You can sure try them, but I dont recommend it. The only deals I found where online, but they were all around the same prices.
