SolaraGuy.com • View topic - Clutch question
Clutch question
Clutch question
Postby methyl mike » Thu Aug 11, 2005 5:18 pm
Ok so lately my car has been shuddering real bad when i first start driving in the morning, yes i warm up at least 5 min every morning, so its not that. The transmission seems to have a hard time catching in first and sometimes second when i first start driving, so im thinking this is the clutch going, so I want to know-is this my clutch going? If it is, whats the best clutch to buy, and where is the cheapest place to get it? Thanks for the input.
methyl mike
Postby methyl mike » Thu Aug 11, 2005 5:20 pm
Wow check this out i think this is a genuine OEM toyota clutch kit, for under 200! Would this be the best or no?
http://shop.toyotapartstore.com/?make=TO&year=1999
methyl mike
Postby methyl mike » Thu Aug 11, 2005 5:28 pm
http://cgi.ebay.com/ebaymotors/ACT-4Pad ... enameZWD1V
Hey check that out, is that an entire clutch or just a plate? If I want like a very strong, very good clutch, would I want to kind of mix and match parts or something? I know NOTHING about clutches, so please bear with me.
methyl mike
Postby methyl mike » Thu Aug 11, 2005 5:31 pm
http://cgi.ebay.com/ebaymotors/ACT-HDMM ... enameZWD1V
check that out its more expensive but would it be worth it?
methyl mike
Postby DatSRBoi » Thu Aug 11, 2005 6:10 pm
Your clutch will still last you. Its jsut the clutch is not really wearing, just getting use allot..Plus A car warming up doesnt warm up your clutches.., Not the stage of danger yet... If your going to replace it, Might as well go for a racing clutch or some sort where its stronger to somewhat last longer for daily... My car does it too but after driving awhile it goes away...So yeah... Good luck..
Postby JAYDEE23 » Thu Aug 11, 2005 6:40 pm
check your clutch fluid..if it is low you will have a hard time finding gears and sometime the clutch may "rub" a bit causing slight movements in the car.
JAYDEE23
Postby toy4x4boy » Thu Aug 11, 2005 6:44 pm
My car does it too. Annoying for sure but doesn't seem to be causing a problem.
toy4x4boy
Postby methyl mike » Fri Aug 12, 2005 10:12 am
JAYDEE23 wrote:check your clutch fluid..if it is low you will have a hard time finding gears and sometime the clutch may "rub" a bit causing slight movements in the car.
Clutch fluid? How do I check that?
methyl mike
Postby jhenty » Sun Aug 14, 2005 12:49 pm
make that thing last as long as possible, i just had to have mine replaces and it was 9 hours labor at the mechanic, however i did replace it with all performance stuff.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby JAYDEE23 » Mon Aug 15, 2005 7:23 am
dont know i will check my manual when i get home..in my last car it was a brake fluid like container..you use brake fluid as clutch fluid in some cars..
JAYDEE23
