SolaraGuy.com • View topic - Rim and tire Fitment
Postby JAYDEE23 » Thu Aug 18, 2005 8:34 am
BOLT PATTERN IS 5 X 114.3
I BELIEVE THE REST OF THE SPECS ARE OK BUT SOMEONE MIGHT WANT TO CONFIRM THIS..BOLT PATTERN IS NOT HOWEVER
JAYDEE23
Postby indiglosolara » Thu Aug 18, 2005 9:01 am
for 18x8 i would go with a 40 offset. that will sit pretty flush with you fender and in your wheel well without rolling or cuting the rear fenders.
Also the Solara can only use 5x114.3 bolt pattern as stated above.
with 8" wide rims you should go with 235/40 tires. 245 it too wide and will rub. I tried 245 with my 8.5 wide rims and i was rubbing big time.
hope this helps
indiglosolara
Solara 2 xB
Solara 2 xB
From Experience
Postby JMSinMaryland » Thu Aug 18, 2005 11:02 am
225/40 18 with a 18x7.5 with 45 offset. No rubbing no issues. Jon.
JMSinMaryland
Postby rossman945 » Mon Aug 22, 2005 5:37 pm
Hey,
Well this weekend I put some 18 inch rims and 235-40-18 sized tires, and for the back, the rear tires rubbed on my struts. To fix this I had quater inch spacer plates put on. The front tires cleared perfectly with no rubbing.
Ross
rossman945
Postby indiglosolara » Tue Aug 23, 2005 8:55 am
rossman945 wrote:Hey,
Ross
whats the offset on your rims?
indiglosolara
Solara 2 xB
Solara 2 xB
Postby rossman945 » Tue Aug 23, 2005 2:12 pm
Whats the offset?
rossman945
Users browsing this forum: No registered users and 110 guests
