SolaraGuy.com • View topic - Will Gen 2 Stock Wheels+tires fit my Gen 1?
Postby Sap Z » Mon Aug 22, 2005 12:24 pm
I was looking to buy the Gen 2 OEM wheels and was wondering if its as simple as bolt on :angel: or are they totally different sizes :o
SapZ
V6 SE DWP
Sap Z
Postby 1st Gen Sol » Mon Aug 22, 2005 12:47 pm
All you need is a set of H&R 5mm spacers for the rear so it doesn't rub against your struts.
Otherwise they will fit b/c other on the forum have done it before and "SolDoubt" has just recently done it.
Here is his link if you wanna see how they look....
http://www.solaraguy.org/viewtopic.php? ... 52b1b7c16d
I was gonna do it but decided on a set of aftermarket wheels instead.
If your looking at "TranSolara's" wheels, I can vouch that he is offereing them at a great price in great condition with two minor scuffs that are repairable if you choose.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby ~Spadwaller~ » Tue Aug 23, 2005 12:12 am
1st Gen Sol wrote:All you need is a set of H&R 5mm spacers for the rear so it doesn't rub against your struts.
"H&R 5mm spacers" are you sure??
~Spadwaller~
Postby ICrazyChrisI » Tue Aug 23, 2005 3:52 am
I would suggest larger than 5mm if you're going to stick w/ a JIC suspension. Hell, even with my 15mm spacer its so damn close to rubbing my coilovers its insane..
ICrazyChrisI
Postby 1st Gen Sol » Tue Aug 23, 2005 6:03 am
~Spadwaller~ wrote:"H&R 5mm spacers" are you sure??
^^^^ You can go with bigger wheels spacers. Just be advised that the threads for your lug nuts will be a lot less and the wheels won't be held on as securely.
That I know of most have gone with 5mm spacers in the rear but not all.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby SleeperSolara » Tue Aug 23, 2005 11:44 am
Yeah if you use a 5mm spacer you might want to look for loner wheel studs.
Thinkin' about get Gen 2 rims for my Gen 1; not sure though.
Postby Sap Z » Tue Sep 13, 2005 11:50 am
BUMPPP !!!
i'm finally going to replace tires cuz a mechanic just told me my tires were almost bald!!
anyways - i have a bone stock 2000 lara..not lowered or anything. WiLL I STILL NEED SPACERS for putting on Gen 2 wheels??
WHERE DO I GET THEM FROM?
Also what size tires should i get on them?
any imput is greatly appriciated.
thanks
SapZ
V6 SE DWP
Sap Z
Postby Sap Z » Wed Sep 14, 2005 9:49 am
bump?
SapZ
V6 SE DWP
Sap Z
Postby JAYDEE23 » Wed Sep 14, 2005 2:04 pm
no personal experience but i have read many time 5mm w/ everything stock will fit gen 2 wheels on gen 1
JAYDEE23
Postby Solorange » Wed Sep 14, 2005 7:05 pm
I thought someone not too long ago put gen two wheels on a gen1. They posted pictures. Search and see what you find. They can answer you question.
Postby ~Spadwaller~ » Wed Sep 14, 2005 7:12 pm
ICrazyChrisI has them and he used 25mm H&R kit
~Spadwaller~
Postby Sap Z » Thu Sep 15, 2005 6:47 am
thx
SapZ
V6 SE DWP
Sap Z
Postby Astro » Thu Sep 15, 2005 8:26 am
Here's the post with pics that Chris had:
http://www.solaraguy.org/viewtopic.php?t=8338&highlight=
