SolaraGuy.com • View topic - installing clear corners....
Postby SolaraBlue » Thu Sep 01, 2005 3:16 pm
sorry guys, searched the forum didnt find anything to tell me how to install clear corners. please help.
-thanks
Postby SC V6 » Thu Sep 01, 2005 3:19 pm
pop the hood... on the clear corner there is a screw that screws into a plastic piece and into some metal.. unscrew that and push the clear corner towards the back of the car.. it will slid out... install in reverse
SC V6
Postby Sap Z » Thu Sep 01, 2005 3:20 pm
ok..i havent done it on my lara but its generally the same way.
there should be a screw that attaches it to the frame. once that is off the light is generally held using a nipple...yes i said nipple!
put on it gently n it should come rite off. i dont know how many srews there r initially..i will chk n let u know if no one else replys here
SapZ
V6 SE DWP
Sap Z
Postby Deion » Thu Sep 01, 2005 3:25 pm
Dont forget about the clip where the corner meets the headlight.... I just used a thin piece of metal and wrapped it in a paper towel, so it won't scratch anything, to slide between the two to depress it when taking out the old corners.
Deion
Postby SolaraBlue » Thu Sep 01, 2005 3:49 pm
SC V6 wrote:pop the hood... on the clear corner there is a screw that screws into a plastic piece and into some metal.. unscrew that and push the clear corner towards the back of the car.. it will slid out... install in reverse
its not moving much, do i have to take the corner bulb out first? or just unscrew the screw and slide the corner back?
Postby Jon11582 » Thu Sep 01, 2005 4:06 pm
Unscrew one screw, Pull the corner lens off, then take the bulb w/ holder out of the lens, put it into the new lens, push the new lens back, and screw it back in.
Nothing else is necessary...and I dont remember a clip that meets the headlight. Just a clip that meets the frame on the outside of the corner lenses
2000 Black Solara SE
Jon11582
Postby SolaraBlue » Thu Sep 01, 2005 4:46 pm
i got it. i was pushing the wrong way :oops: thanks for the super quick response.
-thanks much
Postby RichD978 » Fri Sep 02, 2005 3:33 am
ahah where you from ?
RichD978
Postby WTF?? » Fri Sep 02, 2005 11:16 am
SolaraBlue wrote:i got it. i was pushing the wrong way :oops: thanks for the super quick response.
haha its not much to it huh? once you know the procedure, itll take a quick 2 mins to do both.... i know since i always switch out from my stock, to my clears, or to my black-housed corners... lol
btw, what yr is ur solara? just seeing which blue you got
Retired... its been fun Image
WTF??
