SolaraGuy.com • View topic - Pimp A$$ Cooling System
Postby StockSolara » Sun Sep 11, 2005 4:49 pm
Just recently I had my timing belt tensioner replaced. . . and along with that they changed my timing belt and water pump too. . . So yeah my mechanic told me the timing belt was pretty stretched out. . . I wonder how that happen. . . :angel: . . . hahaha. . . but yeah anyways. . . I have the:
-Koyo Double Row Radiator
-Perma-Cool Engine Oil Cooler
-TRD 160 Degree Thermostat
-TRD Radiator Cap
-Redline Water Wetter
Now I have truly seen the results of upgrade all of this. . . When I am cruising on the highway the meter would be about 0.5-1 centimeter below the mid point on the temperature gauge. . . At first I thought it was because last night was really cold but when I was driving to and home from work. . . the meter will still stay 0.5-1 cm below the mid point when I'm on the highway. . . When I'm on the local streets it will go up a little bit. . . On the stoplight depending on how long it takes the light to turn green. . . it might go back to the middle but either way when I start moving again after a little bit you will notice the meter starting to go down again. . . :D
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby jazzlara » Sun Sep 11, 2005 4:52 pm
What is a water wetter?....does it make water...wetter??
jazzlara
Postby StockSolara » Sun Sep 11, 2005 5:02 pm
jazzlara wrote:What is a water wetter?....does it make water...wetter??
http://www.redlineoil.com/products_coolant.asp that will explain everything to you. . . my friend
2000 Lexus GS400
StockSolara
Postby SleeperSolara » Sun Sep 11, 2005 5:17 pm
Really you have a Koyo Double Row Radiator.
Where you get that.
Was goin' to use Water Wetter......
So your temp gauge moves up and down it don't stay still.
Postby hskrsolara » Sun Sep 11, 2005 5:45 pm
Where did you get all that stuff? Sounds like its working good.
hskrsolara
Postby StockSolara » Sun Sep 11, 2005 5:51 pm
SleeperSolara wrote:Really you have a Koyo Double Row Radiator.
Where you get that.
hskrsolara wrote:Where did you get all that stuff? Sounds like its working good.
I got the
-Koyo Double Row Radiator from Auto Radiator Outlet 1-800-252-0333
-Perma-Cool Engine Oil Cooler from www.jegs.com
-TRD Thermostat from Bill G Email: sales@anythingtoyota.com
-TRD Radiator Cap from www.toyotaparts4u.com
-Redline Water Wetter from local shop
2000 Lexus GS400
StockSolara
Postby DatSRBoi » Sun Sep 11, 2005 6:18 pm
Darn lucky you... Your car may be cooler, But Im hotter :)
Postby Astro » Sun Sep 11, 2005 6:21 pm
That's cool. I just need the oil cooler, but I'm not sure on the water wetter. I don't think it'll make very much difference. But, I'd like to see the difference with and w/o it.
Postby dominoSLEV6 » Sun Sep 11, 2005 6:28 pm
That stuff really all works that well?
How mnuch did that end up runnign you all together?
-chris
dominoSLEV6
Postby SleeperSolara » Sun Sep 11, 2005 6:28 pm
Thanks man. Will see if they have any stock left over.
Postby Astro » Sun Sep 11, 2005 6:32 pm
I forgot about this...[url=http://store.summitracing.com/default.asp?target=eadvsearch.asp&SearchType=Make]FAL Electric Fans
[/url]
This fan should help even more (this is the one that Rizal got).
Postby impactX » Sun Sep 11, 2005 7:53 pm
AKA you wasted your money and your car is not running at optimal temperature.
impactX
Postby Mandarinsolara » Sun Sep 11, 2005 8:04 pm
^lol wtf
Mandarinsolara
Postby hskrsolara » Sun Sep 11, 2005 8:05 pm
hskrsolara
Postby Astro » Sun Sep 11, 2005 8:12 pm
impactX wrote:AKA you wasted your money and your car is not running at optimal temperature.
What are you talking about? It's not like we have a choice of a 4 row radiator. Maybe these things aren't worth the money you have to spend to get some cooling, but these will make a difference - especially if your boosted. :P I know that with the mods I'm currently doing, it'll definately help.
