SolaraGuy.com • View topic - URD Supercharger Fuel Upgrade Kit
Postby ~Spadwaller~ » Wed Sep 14, 2005 7:26 pm
Is this worth buying or jim fuel upgrade better?
"http://www.urdusa.com/product_info.php?products_id=110000017"
~Spadwaller~
Postby DaTwUnKrAziEpInOy » Wed Sep 14, 2005 8:05 pm
I think Jim's Fuel Upgrade consists of a fuel filter and some fuel lines that feed into the fuel rails to feed fuel equally to both fuel rails. And the URD supercharger fuel upgrade includes a Walbro 190L fuel pump, larger injectors, some other stuff. Hope this helps...
DaTwUnKrAziEpInOy
Postby ChargedSolara » Thu Sep 15, 2005 12:43 pm
what setup are you running? if you are running higher than 4psi i would highly recommend the URD kit. with my setup running at 5.5 psi i put it on a dynopack and they couldn't tune the car w/safc2 cuz the car was starving for fuel..jims' fuel upgrade alone isn't enough. the car was throwing the code for running lean.
2008 C6 LS3
ChargedSolara
