SolaraGuy.com • View topic - TRD instructions
TRD instructions
TRD instructions
Postby ~Spadwaller~ » Fri Sep 23, 2005 8:49 am
Can any one post the "TRD rear sway bar" and the "TRD front strut bar" instructions PDF?
~Spadwaller~
Postby CASTRO » Fri Sep 23, 2005 9:16 am
front strutbar is a no brainer. Remove the 3 nuts from each side, install the strutbar as one unit, and reinstall the 3 nuts.
Rear, just install the same way it comes out. There is a total of 4 bolts, and 2 nuts at the endlinks. Only hard part about the install is prolly getting the bar over the exhaust. Some have to take it out, and like me, you just gotta take your time and find a way through. I just had to take our my driverside tire. Hope that helps.
CASTRO
Postby ~Spadwaller~ » Fri Sep 23, 2005 9:30 am
What you use the washers from the old front strut bar?
~Spadwaller~
Postby StockSolara » Fri Sep 23, 2005 11:00 am
RSB http://www.toyotaaccessory.com/store/in ... 30-010.pdf
FSTB You just remove the 4 nuts holding the stock one. . . and the stud that is closest to the engine you will have to put a washer that is included to prop it up a bit so it will stand right. . . Than installing this you will need 2 more nuts since it uses 6 nuts now. . . after you tighten all the nuts just tighten the screw where the bar is connected to the end
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
