SolaraGuy.com • View topic - aghh was installing alarm and now car wont start
Postby pervo » Sat Sep 24, 2005 5:19 pm
here is a thread that ive started.... http://forum.sounddomain.com/ubb/ultima ... p=1#000012
esentialy ive removed the bypass modual and the damn car still wont start
they have guessed that my key lost its programing
any one know anything about reprograming it etc?
:headache!:
pervo
Postby pervo » Sat Sep 24, 2005 8:04 pm
ok i found another key but still nothing
anybody know wtf is going on?
pervo
Postby cRaCkeD oUt » Sat Sep 24, 2005 8:55 pm
ahahah,
take it to the dealer to get it reprogrammed...
....around 40-60 bux
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby DatSRBoi » Sat Sep 24, 2005 9:48 pm
Thast why dont go and do crap you only think you know how to do.. Must know is the answer.. Good luck..
Postby ~Spadwaller~ » Mon Sep 26, 2005 2:36 am
The key:
1. Simultaneously depress and release the brake and
accelerator pedals 1 time (one instruction kind of hints that you
should hold the pedals down while you insert the master key, the next
step).
2. Insert the master key in the ignition, but do not turn it.
3. Within 15 seconds press & release the accelerator pedal 5 times.
4. Then within 20 seconds press & release the brake pedal 6 times.
5. Within 10 seconds remove the master key, and insert the new key.
6. Within 10 seconds press & release the accelerator 1 time.
7. The security light will stay off after 60 to 80 seconds indicating the re-programming was successful.
8. Remove the new key, and depress & release the brake pedal
1 time.
~Spadwaller~
Postby pervo » Mon Sep 26, 2005 8:20 pm
that is to reprogram the key or the ecu?
pervo
Postby Mandarinsolara » Mon Sep 26, 2005 8:56 pm
key
lol
Mandarinsolara
Postby pervo » Mon Sep 26, 2005 9:04 pm
well that doesnt do my any good
pervo
Postby ~Spadwaller~ » Mon Sep 26, 2005 9:08 pm
to reset the ECU dont you just disconnect the batt?
~Spadwaller~
Postby SC V6 » Tue Sep 27, 2005 6:49 am
you probably need to run a wire or something so the ECU gets the code that it needs to see from the key... you probably knocked a wire off that was around the ignition.. The car needs to see the right code from the key to start
SC V6
Postby pervo » Tue Sep 27, 2005 7:36 pm
SC V6 wrote:you probably need to run a wire or something so the ECU gets the code that it needs to see from the key... you probably knocked a wire off that was around the ignition.. The car needs to see the right code from the key to start
thats what it acts like but cant find the suspect wire :cry:
pervo
Postby krook » Thu Sep 29, 2005 6:55 pm
were you tryin' to do remote start?
look around your key cylinder at the top for a black ring with wires running out of it. that's what sends the code from the transponder in your key to the ignition, thus allowing it to start.
krook
