SolaraGuy.com • View topic - HELP !! Guys with HID's please read
Postby Sap Z » Tue Sep 27, 2005 10:32 am
i went out during lunch to try out my new HID's..
but they dont work..i :cry: tried both sides and both bulbs. i wanna cry :puppydogeyes:
Heres the question - can you plz tell me how many pins the plug that goes into the stock harness have?
i think its supposed to have 3 - 2 for the sies and one in the middle top. i also noticed a lotta finger prints on the bulb shild ( tht metal thing around)
do you think the bulbs are burned?
Plz respond ASAP
SapZ
V6 SE DWP
Sap Z
Postby StockSolara » Tue Sep 27, 2005 10:36 am
Your suppose to only have two. . . the 3rd is for high beam. . . unless you bought the kit with highbeams. . . if they dont work that means you plugged them in wrong
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Sap Z » Tue Sep 27, 2005 10:38 am
well...then i dont know what could be wrong..there is only one way to plug it in...you think the kit is bad?
i dont know..:(
SapZ
V6 SE DWP
Sap Z
Postby cklinh » Tue Sep 27, 2005 10:42 am
Did it _ever_ work?
cklinh
Postby Sap Z » Tue Sep 27, 2005 10:44 am
no no..i was just installing them for the first time.
i dont know..maybe the bulbs are bad? has this ever happened to anyone before? i tried pulggin it differently n it still doesnt work..
SapZ
V6 SE DWP
Sap Z
Postby SC V6 » Tue Sep 27, 2005 10:56 am
all you have to do is make sure you are getting the pins in correctly.. try switching them... you probably have the pins hooked up wrong...
SC V6
Postby Jon11582 » Tue Sep 27, 2005 10:56 am
Maybe you flipped the plug.
The way that my friends came from mcculloch, the (grey, I think) connector was apart from the wire terminals, and you need to slip them into the grey plug. If you flip the two, the bulbs wont go on.
Also, the metal box (I cant think of the name right now for some reason) needs to NOT TOUCH any metal on the car. If you do that, they can either stay on all the time, or not come on at all.
2000 Black Solara SE
Jon11582
Postby SC V6 » Tue Sep 27, 2005 10:58 am
ballast
SC V6
Postby Sap Z » Tue Sep 27, 2005 11:00 am
i thought about all that. i flipped the plugs too.
do th ebulbs go bad if connected wrongly? i made sure the ballast doesnt touch the metal too. i gess i will try again when i go home. what do you do with the ignitor? is it supposed to be pounted any place specific?
SapZ
V6 SE DWP
Sap Z
Postby Sap Z » Tue Sep 27, 2005 11:01 am
i wanna cry..i have always wanted these friggin lights...
SapZ
V6 SE DWP
Sap Z
Postby SC V6 » Tue Sep 27, 2005 11:03 am
its fine.. trust me.. its probably just a simple issue... it won't damage the lights... the plugs can be re-wired because you can take the pins out and move them.. its probably just the pins in the wrong place... its not a huge issue... just chill out a bit.. its all good.. just trial and error
SC V6
Postby WTF?? » Tue Sep 27, 2005 11:07 am
For the 2000 Solara, holding the electrical harness facing towards you, you would plug in the black wire on the top slot and the white wire into the right slot.
I noticed for 99 and 01 Solara's its the other way around with white on top and blk on the right.
Once its in and the HIDs work, do your fogs work?
I also noticed the 2000's might be wired differently with lighting
Keep in mind to NOT keep flipping on n off the HIDs... this will decrease the life expectancy of the bulbs. And you can mount the ignitor anywhere
Retired... its been fun Image
WTF??
Postby Sap Z » Tue Sep 27, 2005 11:10 am
thts wierd...
my stock harness has 3 holes rite..
and the HID pulghas 2 pins. it has a blue wire and the red wire. Can you guys check which side yours are on?
SapZ
V6 SE DWP
Sap Z
Postby WTF?? » Tue Sep 27, 2005 11:16 am
Sap Z wrote:thts wierd...
Red and blue???? :crazyeyes:
well just try the top slot and right slot... flip the other way around if it doesnt work... and yes stock harness has 3 slots... one will be open unless you bought the dual filament HIds
Like SCV6 says, its trial and error for now unless you have wire testers
WTF??
Postby Sap Z » Tue Sep 27, 2005 11:31 am
i searched and search... i found this topic and will try this after work
http://www.solaraguy.org/viewtopic.php?t=19214&highlight=hid+wiring
SapZ
V6 SE DWP
Sap Z
