SolaraGuy.com • View topic - Suspension Bolts
Suspension Bolts
Suspension Bolts
Postby Ford_Fixorrepairdaily » Tue Oct 04, 2005 8:07 am
I ve been having probs with my jic suspension, mostly the right front. It seems to bottom out any small bump. I think the problem could be the bolts on the struts. THe shop that i actually took it too about a year ago stripped the bolts or something and replaced it with something smaller w/o my knowledge. I called a couple toyota dealers and theyre no help. THe parts representative that I talked too insisted that it was the camber bolt, but I dont it is. Its (2) 22mm bolts that belong on the strut. I was wondering if anyone has had the same prob and would it really effect the performance? Any help is appreciated
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby cdeez » Tue Oct 04, 2005 8:26 pm
im having the same problem with my driver side one. it seems like im bottoming out on small bumps, its like a clicking noise as if something is loose, but i have taken it to two shops and they say its fine and nothing is loose...i don't think that helped, but i just wanted to share that so you don't feel like the only one.. :wink:
last standing...
Socalara...
cdeez
Postby Ford_Fixorrepairdaily » Tue Oct 04, 2005 9:48 pm
Thanks man I appreciated it. I adjusted my suspension and made it a lil higher the problem went away , but only when im at a higher height. It should be able to handler the lower height no prob. Im gonna take apart my suspension and inspect it again. Thanks cdeez
Postby krawzyazn » Wed Oct 05, 2005 9:46 am
did you call me yesterday james?
Postby Ford_Fixorrepairdaily » Wed Oct 05, 2005 10:55 am
No, I was waiting for your call. haha Okay I'll call you today.
