SolaraGuy.com • View topic - manual swap no reverse lights..
Postby supamouse09 » Fri Oct 07, 2005 11:53 pm
hey i did the manual swap and i forgot that after the swap my reverse light arent working? is there anyway to wire it up to work?? im running the auto ecu still. funny idle because it thinks its always in neutral. is that why my reverse lights dont work??
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby SC V6 » Sat Oct 08, 2005 7:28 am
on the manual tranny there should be a reverse sensor... it will have two wires coming out of it, and one is a ground, and the other is a power if I remember.. and it has to be spliced into the old auto connecter... ill see if I can't get a pic or 2
SC V6
Postby SC V6 » Sat Oct 08, 2005 7:31 am
what did you do to trick the ecu so you don't get shift selonoid errors and reverse switch codes?
I've got a few tips if you want them...
SC V6
Postby StockSolara » Sat Oct 08, 2005 1:09 pm
How much did it cost for parts and labor? I been wanting to do this for a long time now
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SleeperSolara » Sun Oct 09, 2005 2:28 pm
StockSolara wrote:How much did it cost for parts and labor? I been wanting to do this for a long time now
I think it about a grand to 2 grand to get it done.
Postby SPF 0 » Sun Oct 09, 2005 3:41 pm
Don't forget a likely drop in your car's resale value as well. Important when you're adding up what the project will <i>really</i> cost.
SPF 0
Postby supamouse09 » Tue Oct 11, 2005 9:05 pm
any luck with those pics scott??
supamouse09
Postby i20solara02i » Tue Oct 11, 2005 10:11 pm
SPF 0 wrote:Don't forget a likely drop in your car's resale value as well. Important when you're adding up what the project will <i>really</i> cost.
not if you plan on keeping your solara. :evilbat:
i20solara02i
Postby SPF 0 » Wed Oct 12, 2005 7:57 am
rufus129 wrote:not if you plan on keeping your solara.
Unless you plan to drive it until it's only suitable for a scrapyard, it'll have an affect.
SPF 0
Postby SC V6 » Wed Oct 12, 2005 8:33 am
supamouse09 wrote:any luck with those pics scott??
no I forgot completly... send me a PM on friday, and I will try to snap a few pics... its not that bad... do you have the reverse sensor that is plugged into the tranny?
SC V6
Postby StockSolara » Wed Oct 12, 2005 11:26 am
http://tt-cc.com/ratko/swap/index.html
This might help you out with the wiring
2000 Lexus GS400
StockSolara
Postby SC V6 » Wed Oct 12, 2005 11:55 am
yeah thats what I used... but keep in mind he has a camry... I ended up having to checking the wiring diagrams in my chiltons
SC V6
Postby SC V6 » Wed Oct 12, 2005 12:30 pm
by the way.. hows it running? Get the CEL's taken care of so you run w\o CEL's?
SC V6
Postby Midias » Fri Oct 14, 2005 1:57 pm
I just replaced mine it was $26 at advance auto parts
