SolaraGuy.com • View topic - rough ride with Eibachs?
Postby Stunnd » Tue Oct 18, 2005 9:47 am
I recently had Eibach pro-kit lowering springs installed. Then I had a four-wheel alignment done. Cornering is amazing but on straightaways the steering wheel SOMETIMES shakes a lot and the car seems to feel the road much more than I thought it would. Is this normal? :bad-words:
Stunnd
Re: rough ride with Eibachs?
Postby StockSolara » Tue Oct 18, 2005 10:30 am
Stunnd wrote:I recently had Eibach pro-kit lowering springs installed. Then I had a four-wheel alignment done. Cornering is amazing but on straightaways the steering wheel SOMETIMES shakes a lot and the car seems to feel the road much more than I thought it would. Is this normal? :bad-words:
If you didn't get aftermarket struts than yes you should feel more of the ground
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby hskrsolara » Tue Oct 18, 2005 10:37 am
What size of wheels are you running?
hskrsolara
Postby Sap Z » Tue Oct 18, 2005 12:14 pm
i thought thts wat the goal of lowering was...i mena the 'feel the road ' part..
dunno bout the shaking
SapZ
V6 SE DWP
Sap Z
Postby rollaevo99 » Tue Oct 18, 2005 12:37 pm
yeah! lowering your car has nothing to do with shaking......unless you might want to balance you tire......and remember you have to do some alignment after that.....
I used Eibach on my 04.........but I don"t have that problem 8)
Postby Stunnd » Tue Oct 18, 2005 5:15 pm
I'm running on 17" rims. Probably should have gone with some struts too. The speed shop I went with sucked as far as knowing what he was doing. Shouldn't he have at least brought it to my attention that the ride might be kind of rough without new struts? He also screwed up by not informing me about the rear inner support bar coming out when he put on a body kit. It won't pass inspection without it, unless you can find a shop to pass it as is. Am I expecting too much from this guy? :agrue:
Stunnd
Postby bassthrive » Tue Oct 18, 2005 6:23 pm
Make sure your bumpstops are cut in half if you feel like you bottom out a lot. If it is a simple question of ride comfort, you'll eventually get used to feeling the road more. After lowering with tein/tokico, I honed my A-game when it comes to dodging road impefections
Shaking or vibration would be due to wheel balance, not suspension. If shaking occurs while braking, you may need to resurface/replace your rotors.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby WTF?? » Tue Oct 18, 2005 6:30 pm
with 17s your car should ride like a stock car since it still has quite a bit of cushion on the tires
Stunnd wrote:He also screwed up by not informing me about the rear inner support bar coming out when he put on a body kit. It won't pass inspection without it, unless you can find a shop to pass it as is. Am I expecting too much from this guy?
What do you mean by "rear inner support bar" when putting on a body kit????
Unfortunately, I believe you shouldve done more research into what you were getting yourself into. Im not trying to put the fault on you, but I mean in terms of the benefits AND downsides to lowering your ride. Theres gotta be reasons why you do things and gota be aware of what its for... yes you can corner, but now you have the shaking.. why? well since you have 17s Im assuming theyre aftermarket wheels so Id suggest you balance your wheels... who knows what the shopguy did to those wheels after he took em off... they are there to just make their money... some are jackasses, others are reputible and helpful
IF you dont want to upgrade your struts yet, maybe look into thicker tires to cushion more of your ride quality.... Id say 215/50/17? I ran on 215/45/17 and those were hella cushion for me lol... but I, and many other members on this board, would say Eibachs have been a well recommended brand for lowering our solaras...
Time to spend MORE MONEY!!!! :drinking:
Retired... its been fun Image
WTF??
Postby StockSolara » Tue Oct 18, 2005 11:32 pm
Make sure your lugs are torque to spec cause it might be loose an can causing vibration. . . But yeah w/o struts the car is rougher on the road you will be very bumpy
2000 Lexus GS400
StockSolara
Postby Jai_Jai_Binks » Wed Oct 19, 2005 12:21 pm
^^ Not really true. Unless your stock sturts were really bad to begin with. I've got trd's w/ stock struts. My ride is not bumpy and no i don't feel the roads. The only time i notice its lowered when going over pot-holes and/or speed-breakers. I know that in time i will need to change my struts. I've had this set up for the past 24K miles so i speak with experience.
Postby SolaraBlue » Wed Oct 19, 2005 4:06 pm
Jai_Jai_Binks wrote:^^ Not really true. Unless your stock sturts were really bad to begin with. I've got trd's w/ stock struts. My ride is not bumpy and no i don't feel the roads. The only time i notice its lowered when going over pot-holes and/or speed-breakers. I know that in time i will need to change my struts. I've had this set up for the past 24K miles so i speak with experience.
OH SNAP!
Postby Mandarinsolara » Wed Oct 19, 2005 4:32 pm
why am i just now hearing about this?
time for the tein's baby!
Mandarinsolara
Postby Stunnd » Wed Oct 19, 2005 5:21 pm
I did some research but maybe it wasn't enough. Thanks for all the info, you guys rock.
:drinking:
Stunnd
Postby Stunnd » Wed Oct 19, 2005 5:24 pm
I was told the Eibachs were better than Teins. Could there be that much of a difference? Aren't they both topoftheline?
Stunnd
Postby Stunnd » Wed Oct 19, 2005 5:29 pm
WTF?? wrote:with 17s your car should ride like a stock car since it still has quite a bit of cushion on the tires
The inner support bar is the steel reinforcement bar that's attached to the frame. The rear bumper covers it when attached. The ViS rear bumper would not fit on the car without removing the support bar. I found nothing on this issue when looking into bodykits. I didn't even know this bar existed until the shop told me they couldn't put it back on.
Stunnd
