SolaraGuy.com • View topic - CAI extension question
Postby Deion » Wed Oct 19, 2005 3:28 pm
Hey guys!
I just got my CAI extension from RJ. In the box is a single 90 degree bent pipe and the silicone connection. Am I missing anything? I can't see how it goes down into the wheel well like the pics of your guys'.
Deion
Postby Astro » Wed Oct 19, 2005 3:44 pm
:D Here ya go:
Postby Deion » Wed Oct 19, 2005 3:51 pm
awsome! looks like its gonna be an easy install.
Did you take the fusebox out to do the install? I couldn't figure out how to remove it. Did you have to cut your wheel well? Is that just preference or is that needed for the install?
Oh, and I only found 1 of those metal clamp rings, is there supposed to be 2?
Thanks for the help!
Deion
Postby Astro » Wed Oct 19, 2005 4:12 pm
The fusebox has like 2 or 3 clips on the backside on the fender. Mine come off easy now, but I think you could use a phillips screwdriver on the clips.
I just used some pliers to peel back metal there because it wasn't sitting correctly at first. If you find the extension is not lining up with the SR then try doing that.
You should have 3 clamps total, one on each side of the connection and one for the filter. If you don't have one, you can just pick one up at some auto store.
Postby WunLoudSolara » Wed Oct 19, 2005 4:33 pm
hey, i jus got mine today as well and installed it, it also came with only one clamp, but after I was done I just went to Advance and got another. Sucks that they only sell them there in a 2-pack. Home Depot or Lowes has singles tho. Really easy install though, only about 30 minutes.
2000 Toyota Solara SE V6
Injen CAI
Gredy Evo
2 Power HX2 15
RF Power 1500bd & 450s
Sony CDX-M850MP
200Amp EA Alternator
Optima Blue Top Battery
MB Quart Premium 6 1/2 Components
WunLoudSolara
Postby StockSolara » Wed Oct 19, 2005 11:25 pm
Yeah I would say the hardest part of the install is taking off the snorkel cause the screws are hard to get too but yeah if you had it removed than the install will go by quicker
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Aaron » Thu Oct 20, 2005 3:27 pm
I just recieved mine also. But the pipe wont fit thru the hole. I have a camry, does that make a differance? It seems like i need to cut it out or something.
Aaron
Postby Astro » Thu Oct 20, 2005 5:00 pm
Aaron wrote:I just recieved mine also. But the pipe wont fit thru the hole. I have a camry, does that make a differance? It seems like i need to cut it out or something.
Check the 3rd pic I posted above ^^^. I didn't cut it, I just used some pliers to fold it back.
Postby hskrsolara » Thu Oct 20, 2005 6:46 pm
Yep, I did the same thing as Astro.
hskrsolara
Postby DaTwUnKrAziEpInOy » Thu Oct 20, 2005 9:21 pm
Hey that looks really clean Astro... *thumbs up*
DaTwUnKrAziEpInOy
Postby Sp33d » Thu Oct 20, 2005 10:46 pm
the snorkel is bugging the crap out of me. askldfjasalskf some poeple have said that you could take out the snorker without taking the relay and fuse out, is this true? or will i be forced to take out the relay and fuse to do the install?
-mark
Sp33d
Postby RJ@UPFD » Thu Oct 20, 2005 11:18 pm
WunLoudSolara wrote:hey, i jus got mine today as well and installed it, it also came with only one clamp, but after I was done I just went to Advance and got another. Sucks that they only sell them there in a 2-pack. Home Depot or Lowes has singles tho. Really easy install though, only about 30 minutes.
There was only one clamp???? Did anyone else only get one clamp??? Let me know and I get it fixed...The new guy is sooooo fired....
Later
RJ
I AM NOW WORKING FROM HOME...
Phone:714-901-8343
Mobile: 714-717-2068
Email: RJ2004OC@hotmail.com
RJ@UPFD
Postby Deion » Fri Oct 21, 2005 1:31 am
Mine came with only 1 clamp too.
Later
RJ
Deion
Postby Aaron » Fri Oct 21, 2005 7:03 am
Later
RJ[/quote]
Mine only came with one also. Also is there anyway I can get a black hose connection instead of the red, my INJEN intake came with all black fittings.
Aaron
Postby Sp33d » Fri Oct 21, 2005 9:05 am
mines only came with only one clamp. My name is Manh Tu-Huynh and you shipped mine out to Morgan Hill about a week ago. Thank you.
-mark
Sp33d
