SolaraGuy.com • View topic - bad wear
bad wear
bad wear
Postby jazzlara » Sat Oct 22, 2005 2:58 pm
lowered tein/tokiko
front tires worn more on inside than anywhere else
camber??
jazzlara
Postby StockSolara » Sat Oct 22, 2005 3:50 pm
fa sho
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby jazzlara » Sat Oct 22, 2005 4:00 pm
roger that
jazzlara
Postby Jon11582 » Sat Oct 22, 2005 6:28 pm
I thought T/T setup wasnt supposed to have any camber issues.
Sure sounds like camber though.
2000 Black Solara SE
Jon11582
Postby hskrsolara » Sat Oct 22, 2005 6:48 pm
For camber adjustments, do you just put in some cam bolts into the struts and then that can adjust the pitch of the wheel? My mechanic said that "cam bolts" or camber bolts are the only thing you need. Is this correct?
hskrsolara
Postby DaTwUnKrAziEpInOy » Sat Oct 22, 2005 10:52 pm
don't think you need anything for alignment, the suspension by itself should be enough to get it all straightened out.
DaTwUnKrAziEpInOy
Postby jazzlara » Sun Oct 23, 2005 5:44 am
maybe i should go for an alignment.
jazzlara
alignment
Postby Sentinel » Sun Oct 23, 2005 2:09 pm
You should definately have had an alignment when you got all your springs/struts installed, and its a good thing to do every once in a while. Kinda like balancing your tires.
Too many times on too many cars have I realized WAAAAYYY too late that I should have rotated/balanced or aligned the car. And ended up with ruined tires.
Sentinel
Postby jazzlara » Sun Oct 23, 2005 2:22 pm
^ i had them aligned when installed.
does anyone know where i can get these camber bolts???
jazzlara
Postby StockSolara » Sun Oct 23, 2005 2:27 pm
jazzlara wrote:^ i had them aligned when installed.
Here you go http://www.tirerack.com/suspension/susp ... perfCode=S
2000 Lexus GS400
StockSolara
Postby jazzlara » Sun Oct 23, 2005 2:36 pm
^ much thanks
jazzlara
Postby WTF?? » Sun Oct 23, 2005 7:11 pm
FYI- alignment with camber kits MAY cost a bit more than normal alignments
Retired... its been fun Image
WTF??
Postby sydemoid » Sun Oct 23, 2005 7:54 pm
keep an eye at the ride height of the car, a saggy suspension can also lead to irregular wear of the inner walls on tires.
check the struts out, if they are blown, they will also create a sagging effect leading to negative camber., oh yeah, and the strut mounts, if they are worn out, that has also caused negative camber before.
sydemoid
Postby jazzlara » Sat Oct 29, 2005 5:51 am
$67 total with 2 day shipping for the camber bolts. Ill update when project is finished....handling and tire wear should be positivly affected...hopefully :)
jazzlara
Postby jazzlara » Sat Nov 05, 2005 6:59 am
update: camber was at -1.5 the eibach bolts were the wrong size!! the mecanic instead modified my stock bolts and turned my camber to -1 so hopefully this will help the wear.
returned the camber bolts....all is well.
jazzlara
